Old 03-06-2007, 08:04 AM   #16
Car: 06 sti
IWSTI Addict since: Jun 2006
also, where is the cheapest i can find a replacement? I have seen anywhere from $190-218, anyone know and cheaper places to pick it up? thanks
bhp808 is offline   Reply With Quote
Old 03-06-2007, 08:09 AM   #17
Wheel33tist Whore
IWSTI Addict since: Dec 2004
you may have too many miles on these tires to just change 1 or 2 tires.
T3h_Clap is online now   Reply With Quote
Old 03-06-2007, 09:40 AM   #18
Spiteful Old Codger
IWSTI Addict since: Jul 2003
Les Schwab has quite a few CA locations: http://www.lesschwab.com/locator.asp I'm not necessarily saying they are god's gift to tire service, but they do know how to put on a patch... at least they do up here.
In terms of tire rotation, you basically just want to keep putting the least worn tires into the locations where they are wearing fastest (hopefully Nick won't come along with thousands of charts and graphs to discredit that concept, lol.). If you have a relatively conventional alignment and you don't drive like an idiot, your front tires will probably wear a little faster than your rears. There probably won't be too much variation side/side. Swapping front/rear will solve that. You can also swap diagonally, assuming you aren't using asymmetrical directional tires (unless you don't care about utilizing that feature of the tread design).
I swap my wheels at least 100 times/year, so it's just a matter of paying attention to the tire wear when I put the streets back on - NBD. Even if you don't have another reason to swap, it only takes about 20 minutes to do.
Milage isn't a very good indicator. You could wear out a set of 070's in 100 miles, or they could last 30K miles. It depends on the application. Just check the tread depth on both edges and the middle of each tire, and look for idiosyncrasies.
Old 03-06-2007, 03:24 PM   #19
Car: 06 sti
ok i took out the tacs and 2 very very small leaks, how would i shave the tire down if i purchased a new one? i asked discount tire and they said they dont do that?
Old 03-06-2007, 03:31 PM   #20
Car: 06 sti
thanks but the closest location is 411 miles away, r u sure they put patches on the side wall? not the tread or the shoulder but between where it says bridgestone and the actual rim? im sorry if that is what u were talking about but everyone is telling me it is illegal and they wont do it, how is a big name place like les schwab doing it?
Old 03-06-2007, 03:35 PM   #21
nulla poena sine lege
Car: '08 GT500
IWSTI Addict since: Nov 2003
replace the tire. consider this: a blowout of the sidewall at speed...would you want to be in that position?
QuickSilverSTi is offline   Reply With Quote
Old 03-06-2007, 03:47 PM   #22
Car: '05 CGM
Fav Mod: HPDEs
IWSTI Addict since: May 2006
Here's a link to a Tire Rack article on sidewall tire repairs. Bottom line is it's not recommended.
http://www.tirerack.com/tires/tirete....jsp?techid=77
It sounds like you made a wise choice in getting a replacement tire.
Have you measured the tread depth of your existing tires as well as the replacement tire? You may find that they're close enough that nothing else needs to be done.
As far as shaving is concerned, I don't think you'll find any shop that will shave a used tire. Shaving a used tire can damage the blades used for shaving and so typically only new tires are shaved.
Hope this helps!
Gary
Old 03-06-2007, 09:32 PM   #23
Car: 06 sti
yeah ur right, i honestly have not replaced the tire yet but it will be in the very near future. I cant find a used tire, should i mix and match? i was thinking of getting a new one, so how would i get that one shaved or where?
thanks for the info, thats y im glad i found this website
