Old 02-24-2007, 09:51 PM   #1
Banned
Car: 05 OBP STi
IWSTI Addict since: Aug 2005
Default RAYS GramLights 57F Fitment
Does anyone have any experience with the fitment of the RAYS 57F 18X8.5 45 offset, 5x114.3 on an 05 with JDM pinks or something with a similar drop? Is there any rubbing issues at full lock?
Kurokaze is offline   Reply With Quote
Old 02-24-2007, 10:23 PM   #2
Welcome to The Board
Car: 06 WRB STI
Fav Mod: Advan RS
IWSTI Addict since: Mar 2006
Trader Rating: (15)
Send a message via AIM to Ikon
you know that pinks only drop like an inch or so so im possitive it will fit.
Old 02-24-2007, 11:29 PM   #3
Fav Mod: JDM STi Performance Muffler
IWSTI Addict since: Mar 2004
Front should be fine. You may get slight rubbing in the rear depending on what size tires you run. As long as you don't go too wide you'll be fine.
300hp@6000rpm is offline   Reply With Quote
Old 02-25-2007, 12:28 AM   #4
Banned
Car: 05 OBP STi
245 was the width I was looking at... Kumho ECSTA SPT most in likely.
Old 02-25-2007, 12:32 AM   #5
Car: 08 STi, SSM
IWSTI Addict since: Dec 2005
I have 245/40/18 Bridgestone RE050A Pole Positions with Espelir GT springs and have no rubbing issues so far, even up a steep driveway where I have to enter at near full lock.
Old 02-25-2007, 06:01 AM   #6
Wheel33tist Whore
IWSTI Addict since: Dec 2004
Don't run the Ecsta SPTs if you like performance.
anyway, i ran wheels with that size and offset with a 235/40 18 and i had room for more tire.
Old 02-25-2007, 10:35 AM   #7
Banned
Car: 05 OBP STi
I heard that the SPTs were a good blend of performance, price, and durability. I've been threatening to start autoxing and but my STi is also my daily driver. Any other rubber suggestions?
Old 02-25-2007, 10:50 AM   #8
Wheel33tist Whore
I have a friend with the SPTs and he HATES them, squirmy, squishy, very bad for autox.
he got them for next to nothing and regrets it.
there are much better tires out there for cheap.
RT615
RS2
RE01R (higher side but still)
FK452 (less performance but better life)
The STI deserves a much better tire than an SPT.
what other questions do you have about rubbing?
Old 02-25-2007, 10:54 AM   #9
Car: 05 Subaru WRX STi
Fav Mod: Sways
I've got JDM Pinks, RCE camberplates that give the drop, 57F's and Falklen 615's 245 x 18. I do get rubbing in the back when I take turns hard enough. I havn't worried about it though because you have to be pushing the car pretty hard to get them to rub and I only use those tires on the street. I use a couple of sets of stock ones for the track because the tires are cheeper.
yellowducman is offline   Reply With Quote
Old 02-25-2007, 10:57 AM   #10
Wheel33tist Whore
what camber are you running in the rear?
if you added a little (-.2 more) you could get rid of the rubbing.
Old 02-27-2007, 10:48 AM   #11
Car: 05 S2000
IWSTI Addict since: Aug 2004
I'm interested in this as well, I'm trying to decide what size RT615s to get for those rims. 235s or 245s? I am running KW v3s and I'm afraid too much camber will cause 245 tires to rub the coilover, this is the case on my 255/40/17s on stock BBS rims.
eXstasy is offline   Reply With Quote
Old 02-27-2007, 01:13 PM   #12
Wheel33tist Whore
well i'm running 235s on my 8.5 +45mm wheels with -1.7 rear camber and have ZERO rubbing.
the KW's have a good amount of room inboard, less than the stock struts (obviously).
Old 02-27-2007, 02:52 PM   #13
Car: 05 S2000
Thank you. I just read many different wheel and tire threads where you've contributed greatly. Just wanted to let you know that your input is appreciated.
On a side note, I've decided to go with Falken FK452s instead of RT615s because this will be my street setup. While I love the performance of the 615s, their tread life is not good enough for me on the street.
Old 02-27-2007, 03:24 PM   #14
Car: 01 Subaru WRX STi Spec C
Trader Rating: (14)
I'm running 245's with zero issues on stock height. There's another guy running 245's with Helix DNA's with no issues (mild drop). I hear on 245s with S-techs or lower than 1.5" you will get minor rubbing in the rear, but no problems with the front.
Cheers,
Gary
Gruppe-S
Gruppe-S is offline   Reply With Quote
Old 02-28-2007, 07:30 PM   #15
Banned
Car: 05 OBP STi
Cheers,
Gary
Gruppe-S
Thanks everyone!
Gary,
What tire are you running?
By the by, I pulled the trigger and got a set in black (darkcopse). You said the caps and lugs were included... do I need anything else? ...other than a nice set of tires
