| Amateur STI Driver | What do you guys think about running a 15mm spacer to change my bolt pattern from 5x100 to 5x114? I have an 04 sti, and i would like to do the hub swap but I need to do it in stages. Would you guys not take your car on the track with the spacers? Thanks for the help. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #3 |
| Spec C Club Car: '08 BMW 135i Location: Centerville, Georgia Posts: 1,666
IWSTI Addict since: May 2005 Trader Rating: (13) | What do webbles do? They wobble. 'nuff said. Edit: Oh yeah, and you will probably be changing those wheel bearings pretty soon if you do it. Last edited by MadMan77; 02-14-2007 at 06:34 PM. |
| | #4 |
| Wheel33tist Whore
Car: Aspen White GDF-D Fav Mod: Pastelito Racing / SFSOC Location: 0R!4ND0 Posts: 21,517
IWSTI Addict since: Dec 2004 Trader Rating: (7) | the biggest issue would be to find wheel that would work with a 15mm offset. you'd need to be in the upper 50s high 60s to really be worth the use. and the funny part about that is, the wheels that are available in that offset are more expensive then it'd be to do a hub swap + new 5zigens This ad is not endorsed by this member. Please register or login to hide this ad. |
