| | #16 | |
| Wheel33tist Whore
Car: Aspen White GDF-D Fav Mod: Pastelito Racing / SFSOC Location: 0R!4ND0 Posts: 21,518
IWSTI Addict since: Dec 2004 Trader Rating: (7) | Quote:
![]() no real reason to run that on the street. This ad is not endorsed by this member. Please register or login to hide this ad. | |
| | #17 | |
| Wheel33tist Whore
| | #19 | |
| Wheel33tist Whore
so i'll probably just do the +25mm and be done with it ![]() then work on getting them to fit under the fenders.... j/k <maybe> | |
| | #21 | |
| Wheel33tist Whore
![]() i've got some thinking, number crunching to do, we'll see. maybe i should make some aluminium liners that are further out of the way.... | |
| | #23 | |
| Wheel33tist Whore
![]() I'll be either in BSP, SM, or FP this year depending on what i decide to do with my fenders. you couldn't run those without coilovers (FYI). | |
| | #24 | |
| Amateur STI Driver | Quote:
Coming from the rally scene , I know sometime it's difficult to get a large tires setup without rubbing on the fenders or having the right offset due to coil overs . Your car must be glued to the road now | |
| | #25 | |
| Wheel33tist Whore
i have to figure a few things out. | |
| | #26 |
| Senior STI Driver Car: 05 Subaru WRX STi Fav Mod: Exige Location: Starkvegas, MS Posts: 387
IWSTI Addict since: Jul 2005 Trader Rating: (6) | teh clap, I've been running this setup for about 7 events now. What rates do you have in the front? I have 700 lb springs and I am very close to rubbing fender on tire in some corners. If you are on off the shelf kw rates my guess is you will rub fender. Also, you might want to drop a bit of camber in the rear to promote some rotation but you can figure that out to suit your driving. I just got some 315/35R17 Hoosiers to run at valdosta. I'll let you all know how well massive hoosiers and lots of vf39 boost do against some real competition next month. |
| | #27 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | I plan on upgrading to 9/8 springs later in the year. I don't own these wheel, i was just test fitting. I have a feeling the 17x9 makes the most sense right now, and when i do get the stiffer springs i'll do the 17x10s and make the 17x9s for track duty. plus I may have added front fender clearance in the near future ![]() i had a friend test fit some of those hoosiers and they didn't fit with his 17x10 CCWs. This ad is not endorsed by this member. Please register or login to hide this ad. |
