| Professional STI Driver | I was thinking about buying a set of tires and then storing them for around 2 years before I mount them. Will the structure of the tire get compromised if I store it that long? I was going to wrap them and put them in the garage. I live in Socal so the temperatures are not that extreme. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Poor Speed Racer Car: 96 328 Fav Mod: Tightening the nut behind the wheel! Location: Northern VA Posts: 8,446
IWSTI Addict since: Mar 2005 Trader Rating: (8) | why wait two years? I would say unless they were in a perfectly dry place, no. and even then, two years is a LONG time.. |
| | #3 | |
http://www.automobilemag.com/auto_sh...r_evolution_x/ | |
| | #4 |
| Professional STI Racer Car: 2006 Subaru WRX STI Fav Mod: Maddad DP and P&L Catback, stage 2!!! Location: Omaha, Nebraska Posts: 632
IWSTI Addict since: Oct 2006 Trader Rating: (9) | if u leave tires sittin for too long, like on a rack, it will change shape and u will or might get flat spots. best is to use tires pretty soon and not let them sit around for too long. |
| | #5 |
| STI Driver | Look at the manufacture date on the tire. I believe Bridgestone warranties against defects for up to 6 years after that date. <o></o> Is 2 years a long time on a newer tire? I don’t think so as long as you store them in a cool, dry place out of the sun. Look at all the people running winter/summer tires. Those sets are sitting for 6+ months in some cases and even lasting over 4 years with no issues. Last edited by webcrawlr; 01-08-2007 at 06:05 PM. |
| | #6 |
| Professional STI Driver | Put the tyres in a black garbage bag and keep them away from ozone generators. Next to the furnace with an electric fan motor is a bad place for example. A root cellar would be best... |
| | #7 |
| Professional STI Racer | Put the tires in a plastic bag. You can use a vacum cleaner to suck some of the air out if you want. Then stand them on their tread in some manner. I stood my RT215 in a box. Do NOT stack them on their sides. Cool, dry place out of the sun is a must also. I actually kept a set of RT215 around for over a year before mounting them. Worked pretty good still when I finally mounted them. Really though, why would you wait two years to use them? Do you go through tires that slowly? The only reason I waited on my Falkens is because I ordered them and the shipment got lost. I ordered a different set of tires/wheels during that time frame and had the on my car. Then my Falkens showed up. Didn't need them that summer, winter came and I couldn't use them. Moved and waited till the next summer to mount them. |
| | #8 | |
