Old 11-13-2006, 08:44 PM   #1
Car: 04 Blue STI
Fav Mod: STI Seatbelt Pads :-)
IWSTI Addict since: Apr 2005
Exclamation Lost wheel lock key to Crimson K6's
I think I may have lost my wheel lock for my Crimson K6's...any ideas? My mechanic i'm sure could use his Jesse James tactics to get them off, but I'd rather not...
TIA
TTTT is offline   Reply With Quote
Old 11-13-2006, 08:46 PM   #2
1B4DSTI
Fav Mod: M&J Modified
IWSTI Addict since: Jan 2006
go to the dealer they might have it
Old 11-13-2006, 08:49 PM   #3
Car: 04 Blue STI
the dealer would have a wheel lock for an aftermarket set of rims?
Old 11-13-2006, 08:56 PM   #4
1B4DSTI
are the nuts aftermarket too? if the nuts are the stock ones, they dealer usually has them
Old 11-13-2006, 10:45 PM   #5
Fav Mod: JDM STi Performance Muffler
IWSTI Addict since: Mar 2004
Are you talking about loosing the key to one of your aftermarket locking lugnuts?
Try contacting the manufacturer of the lugs and see if you can get a replacement key. If you can't, I've heard that you can use a hammer to slam a socket over the lug and remove it with an impact wrench. I've also heard other people have used a dremel or cutting wheel to create a cut in the lug and then used a hammer and chisel to effectively split the lug in half.
Once again, those are thing I've read have worked for some people. If you try doing any of those be careful as you run the risk of damaging your wheels, lugs (that's pretty much a given), or studs.
300hp@6000rpm is offline   Reply With Quote
Old 11-14-2006, 02:36 PM   #6
Car: 04 Blue STI
Yes, losing the key to one of my aftermarket lugnuts...
Gonna try to contact the manufacturer..i guess...gonna be interesting..those other methods are a last resort
