Old 11-01-2006, 06:46 PM   #1
Car: '05 STi
Fav Mod: Britax Roundabout
IWSTI Addict since: Sep 2005
Default Question for the wheel experts
Quick question for the fitment experts.
I recently bought some Toyo RA-1s in size 255/40/17 and I have begun to get worried about whether or not they will fit. I am planing on mounting the tires to Rota Slipstreams in 17x8.5 and an offset of 48. The tires measure 10.4 inches wide on a 9 inch wheels. This wheel be a tire and wheel combo used for HPDEs. My suspension is undecided but is between V3s, RCE springs and plates, or RCE coils (?).
Am I going to rub on either the fender or the strut? Did I make a mistake on buying these tires? Do I need a slightly narrower size? My car is an '05.
Thanks for your help.
Andy
Andy STI is offline   Reply With Quote
Old 11-01-2006, 11:57 PM   #2
Fav Mod: JDM STi Performance Muffler
IWSTI Addict since: Mar 2004
I'm no expert but from what I've seen and read, you should be alright. Because you have an 05 you can get away with running wider tires, however the only thing that worries me is that you are running 255/45 tires. Since 255's have the tendency to bulge at the sidewalls and the fact that the tires you're running are slightly taller it may cause rubbing. Most of the people I've seen run 255's used 255/40's and ran them no problem even when lowered (on 17's of course).
300hp@6000rpm is offline   Reply With Quote
Old 11-02-2006, 10:51 AM   #3
Car: '05 STi
Oops, my bad, the tires are 255/40. I too have seen many running 255/40 tires but most of those are narrower than the Toyos.
Old 11-02-2006, 11:07 AM   #4
Poor Speed Racer
Car: 96 328
IWSTI Addict since: Mar 2005
you should be fine.
Old 11-02-2006, 11:09 AM   #5
Car: '04.5 STi
IWSTI Addict since: Apr 2006
You'll be fine.
Old 11-02-2006, 11:11 AM   #6
Indiatr0n in yo IWDPL
Fav Mod: Brum Brum
IWSTI Addict since: Jun 2004
2007 Postwhore King
255 Azenis are not narrow by any means... Of course, I haven't seen the Toyos
Old 11-02-2006, 12:01 PM   #7
Car: '05 STi
Originally Posted by Mykl
You'll be fine.
If I go with KWs I shouldn't have to worry about hitting the strut? Great.
Thanks guys.
Old 11-02-2006, 03:03 PM   #8
Muller Chevrolet
Fav Mod: a new 09 STi
IWSTI Addict since: Oct 2004
you won't rub, with a 48 offset you are a-okay with that wide of a tire (the 255 rt615 are that wide)
VSGTS14 is online now   Reply With Quote
Old 11-03-2006, 07:05 AM   #9
Car: '05 STi
Awesome. Thanks for relieving my fears.
Andy
