| Junior STI Driver Car: 06 Subaru WRX STI' Location: lake charles, LA Posts: 95
IWSTI Addict since: Mar 2006 Trader Rating: (2) | -Are there any fitment or rubbing issues with putting a 245/45 on our stock bbs wheels. Does the extra weight of the rubber outweigh the benefits? -Finally our cars speedo is a little off b/c of our 225/45 tires (jdm is 235/45). We are actually going slightly slower than what our speedo says. So if i put 245/45 tires on will the opposite happen. Will i actually be going a little faster than what my speedo says. The same is for the miles traveled and the odometer. 225/45 tires make our car think it is traveling more miles than it actually is. This ad is not endorsed by this member. Please register or login to hide this ad. Last edited by jsmsustudent; 10-05-2006 at 12:18 AM. |
| | #2 |
| Professional STI Racer Car: WRB 06 WRX STI Fav Mod: Protune Location: Atlanta via Motown Posts: 808
IWSTI Addict since: Aug 2006 Trader Rating: (0) | I've been looking for a definitive answer on this as well... It seems to me that 245/45/17's would be too tall and that 245/40's would be better. I forget which website(I think its tirerack.com) that has a calculator to see diameter's/width... 255/40's are actually the closest match but I'm thinking those'd rub for sure... Then the issue is further confused by manufacturer, Bridgestone 225/45's are wider than xxxx brand 225/45's.. |
| | #4 |
IWSTI Addict since: Aug 2006 Trader Rating: (0) | going by the tirerack calculator... yes... then again there's the difference by manufacturer I mentioned to throw a monkey wrench in the works! |
| | #5 |
| Wheel33tist Whore
Car: Aspen White GDF-D Fav Mod: Pastelito Racing / SFSOC Location: 0R!4ND0 Posts: 21,462
IWSTI Addict since: Dec 2004 Trader Rating: (7) | 255/40 17 RT615s fit on a MY05+ STi on stock wheels even when lowerd on STi Pinks. how do i know? there are alot of us who have done it. and the amount of difference between running a 225/45 17 and a 245/45 17 is like 250 miles per every 10k miles IIRC. |
| | #6 |
| Platinum Member | tire size calulator: http://www.miata.net/garage/tirecalc.html 1) 245/45 or 255/40 will be fine on 05+. Plenty of people running them. 2) The speedo is so far off that it would take something in the neighborhood of a 245/50 to correct it. With a 245/45 you will still be slower than what it says. The odometer is not tied to the speedo and is more accurate. Non-stock tire size may affect the odo, but the difference is like +/- 1% either side of 235. |
| | #8 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | I assume you're running you stock wheels? if not, size and offset would be appreciated to know what fits and what doesn't. |
| | #9 |
| Professional STI Racer | another good one is http://www.1010tires.com/TireSizeCalculator.asp you can see images of various tire size dimensions to give you a reference of how much/less a tire will be. http://www.1010tires.com/WheelOffsetCalculator.asp offset calculator, well its pretty obvious what it does. it only gives you a general idea of the changes. supsension settings will alter the outcome a bit (i.e changing to coilovers) |
| | #10 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | neither of these mention the change in section width with a different width wheel. this is a significant change. |
| | #11 | |
| Professional STI Racer | Quote:
havent found a chart or anything that shows it. sidenote: re01r 245/40/17 weighs 27 pounds re070 225/45/17 weighs 27 pounds | |
| | #12 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | well the "basic" rule is 5mm increase or decrease for every .5" wheel width difference from "measured rim width" mine is the only chart that i know of that takes it into account. |
| | #13 |
| Muller Chevrolet
Car: 08 Chevy 2500 Diesel Fav Mod: a new 09 STi Location: Milford, NJ Posts: 10,144
IWSTI Addict since: Oct 2004 Trader Rating: (11) | if u want to know the diameter, look at thed tire manu. spec all tires run diff sizes you n00bs |
| | #14 |
| Spec C Club
Car: 05 WRB WRX STi Fav Mod: FYI, I'm a dude Location: Burlington, MA Posts: 2,362
IWSTI Addict since: Mar 2005 Trader Rating: (10) | this is helpful info. i'm looking into new tires soon too. so, 245/45/17s and 255/40/17s will fit stock 05 rims and sti pinks. correct? no rubbing or fender rolling necessary? any opinions on which would be better for performance/grip? |
| | #15 |
| ADMIN
Car: 2005 BMW COMP ///M3 Location: Westchester, NY Posts: 1
IWSTI Addict since: Jan 2004 Trader Rating: (13) | I wouldn't put anything larger than a 235/45 on the stock or any 8" wide rim. Yes, a 245 or 255 will fit but it just doesnt make sence. There will be way too much sidewall felx. You want the sidewall to be flat, not boulge out towards the bottom. This ad is not endorsed by this member. Please register or login to hide this ad. |
