Old 10-03-2006, 09:01 AM   #31
Car: 04 JBP STI "The Beas
Fav Mod: Sold the Beast, waitin for 09 Leg STI...Bye baby!!
IWSTI Addict since: Jul 2003
Send a message via AIM to salisburyv
235/40/18....They suck in the rain. Wear is good. Might get another half season...2 months maybe. About to put the winter rubber on next week. I'd buy them again....very sticky once warm.
you are going to be using winter tires right? these tires are not good with temps below 40 degrees...fyi
salisburyv is offline   Reply With Quote
Old 10-03-2006, 10:33 AM   #32
Car: 2005 White/Gold STi
Fav Mod: TD06-20G/Tein Flex coilovers
IWSTI Addict since: May 2005
I'd only be using these tires in the spring/summer/fall, no winter.
pt518sti is offline   Reply With Quote
Old 10-03-2006, 03:56 PM   #33
Car: 05 STi PSM
Fav Mod: Scooby Sport DP
IWSTI Addict since: Sep 2005
If you don't race and don't need absolute grip, buy something else. Used 070's are a good choice, MX, or any of the many good tires around $100.
silver arrow is offline   Reply With Quote
Old 10-04-2006, 11:47 PM   #34
Car: 06 Subaru WRX STI'
IWSTI Addict since: Mar 2006
Originally Posted by Yoo Shin
The 225 RT615 isn't going to be as wide as the RE070s. Even though the Falkens run wide, they're still not as wide as the RE070s. I wish they made a 245/40 in the RT615 but the only have 235/40 which is a we bit small ESPECIALLY WITH STI GEARING, and the 245/45. As for the straight line performance, the 245/45 will add a little bit of rotational inertia/mass too which would hurt performance. To what degree, I don't dunno but if you're were an autoxer they'd be a great choice since the greater diameter would help gearing.
Have you considered the Kooks RS2? They come in a 245/40.
How will a taller tire affect help/hurt our short gearing? Someone please clarify.
jsmsustudent is offline   Reply With Quote
Old 10-05-2006, 12:02 AM   #35
Car: 05 STi, 04 M3, 90 Sp
Fav Mod: Clear bra
IWSTI Addict since: Mar 2005
245/45R17=811 rpm
225/45R17=833 rpm
Tires affect gearing. Think of the effect of adding monster truck tires to something. 1 revolution of the wheel takes more distance, thus gearing is taller. If a tire has 5% bigger circumference, it will roll 5% less times per mile... etc. So what used to read 50 mph now is 52.5 mph, etc. but the stock speedometer is actually very optimistic so taller tires help bring it back to reality.
Taller gearing means less torque but longer speed spent in a gear so for autox, you could hold 2nd longer if you had 245/45R17 as opposed to 225/45R17. So redline would be closer to 60mph than 58mph in 2nd stock.
smurfm3 is offline   Reply With Quote
Old 10-05-2006, 01:28 PM   #36
Car: 05 STi PSM
Originally Posted by smurfm3
245/45R17=811 rpm
225/45R17=833 rpm
For autocross most classes, except stock, allow you to bump the rev limiter. So, 245/45/17 + 7200 rpms = better for autocross.
Old 10-06-2006, 07:03 AM   #37
Car: 05 STI
Fav Mod: Invidia N1-R
IWSTI Addict since: Sep 2004
I will be getting 255-40-17s
KiNgMaRtY is offline   Reply With Quote
