Old 09-28-2006, 12:30 PM   #16
Car: 06 Subaru WRX
Fav Mod: Tanabe Medallion Touring - The Anti G200
IWSTI Addict since: Feb 2006
The 225 RT615 isn't going to be as wide as the RE070s. Even though the Falkens run wide, they're still not as wide as the RE070s. I wish they made a 245/40 in the RT615 but the only have 235/40 which is a we bit small especially with STI gearing, and the 245/45. As for the straight line performance, the 245/45 will add a little bit of rotational inertia/mass too which would hurt performance. To what degree, I don't dunno but if you're were an autoxer they'd be a great choice since the greater diameter would help gearing.
Have you considered the Kooks RS2? They come in a 245/40.
Yoo Shin is offline   Reply With Quote
Old 09-28-2006, 01:30 PM   #17
Car: 2005 White/Gold STi
Fav Mod: TD06-20G/Tein Flex coilovers
IWSTI Addict since: May 2005
Well I definitly don't want something that'll hurt straight line performance..
Why wouldn't they be as wide as the stock tires?
225/45/17 is a 225/45/17, right?
What makes them different?
pt518sti is offline   Reply With Quote
Old 09-28-2006, 01:49 PM   #18
Fav Mod: Driver
IWSTI Addict since: Jan 2006
Send a message via AIM to ruski
Mine have lasted 7 track days and I hope to get 9 out of them, but that is all I use them for.
ruski is offline   Reply With Quote
Old 09-28-2006, 02:26 PM   #19
Muller Chevrolet
Fav Mod: a new 09 STi
IWSTI Addict since: Oct 2004
the manufacturer and what kind of tire it is.
falken's run wide, i think the 245 falken is 9.6 overall length the 225 are smaller obviously.
keep this in mind, if you want straight line performance make sure the tire is lighter...the 245/45 are heavy...27-28 lbs each.
Old 09-28-2006, 02:44 PM   #20
IWSTI Addict since: Apr 2004
They both say 8.9 is their section width. Does that mean they are the same width?
(Click image)
Click here for RE070's
na-STi is offline   Reply With Quote
Old 09-28-2006, 02:52 PM   #21
Car: 2006 STI BLUE
Fav Mod: Fp20g and protune
IWSTI Addict since: Dec 2005
for my next tire i was going to go with the rt615s 245/45/17 .. Should i ?? i track the car and go on alot of canyon runs durning the year . or should i go with a smaller rt615 what do you think .. And from the look of it the rt615s 245/45/17 are only a pound more then the stock tires .. what do you think .. and these are going to be on the stock BBS rim .. I will be also running the RCE spring with mostly groupe N top mounts both rear and front with mabey some camber bolts .. Since i mosly us it for a normal daily driver .. with some whiteline sway bars soon also .. give me your thoughts
Old 09-28-2006, 03:01 PM   #22
Car: 2005 STi
IWSTI Addict since: Jun 2005
Hey Lightwerkz, who is DTD?
Transworld is offline   Reply With Quote
Old 09-28-2006, 04:50 PM   #23
Car: 04 WRB STi
Fav Mod: JDM STi Recaros
IWSTI Addict since: Jun 2006
^^^ + 1
yakmasterjack is offline   Reply With Quote
Old 09-28-2006, 06:32 PM   #24
STI Master
Car: E46 M3
Fav Mod: ZCP Wheels
IWSTI Addict since: Aug 2005
Trader Rating: (77)
Discount Tire Direct
Old 09-28-2006, 06:57 PM   #25
Car: 05 STi, 04 M3, 90 Sp
Fav Mod: Clear bra
IWSTI Addict since: Mar 2005
They're not a long-lasting tire. Expect under 10,000 miles (closer to 5,000 than 10,000 if you track them or drive them hard).
smurfm3 is offline   Reply With Quote
Old 09-28-2006, 11:22 PM   #26
Car: 05 STi PSM
Fav Mod: Scooby Sport DP
IWSTI Addict since: Sep 2005
Kumho MX is a better tire for track days, RT615 better for autocross. MX handle heat better and wear better, but not as sticky.
silver arrow is offline   Reply With Quote
Old 09-29-2006, 08:56 PM   #27
IWSTI Addict since: Nov 2004
Good thread.. I have 225/45/17 RT615s.. great tire after the stock RE070.. I haven't been to any AX yet but at 10k I am almost done. I rotated at around 7.5k thinking that was probably half the life..but I have to change pretty soon now. I have a knack of going fast around on/offramps.. thats pretty much.. If you like the stiff sidewall then stay with the RE070 because even though the RT615 is closely compared to it..still falls behind a bit. My next tire would be again the RE070 since I got 20K out of those. Yes the tread rating is lower on the RE070's but I got more mileage out of them.. I drove them harder btw..since it felt more planted.
Tires are very important and change the feel of the whole car. If you spend a little over 200 on a set I think its well worth it. You are using these tires for at least 10k miles or over..then might as well enjoy them more too. My setup is nothing special.. Prodrive springs/WL 27FSB/24RSB. Will be getting RCE spring/camber plates and ALK. Handling is very important to me so go with the better tire... my 2 cents
FajjaSTI is offline   Reply With Quote
Old 09-29-2006, 09:04 PM   #28
I'm at 30,000 miles on my stockers.. they are bald as Jesse Ventura's head
I'm not sure if I'm going to end up going with the Azenis.. I drive my car a lot and it seems like these just don't last long at all.
Hmmm.. not sure what I'm gonna do.
Old 09-30-2006, 12:13 AM   #29
Car: 2oo5 cgm STi
IWSTI Addict since: Jul 2004
The 245/45 looks perfect on the stock 8" rim. If you really must have a lighter-weight tire, you'll need to look for something with a less-stiff sidewall. Milchelin Pilot Sport PS2 comes to mind.
Old 10-03-2006, 08:55 AM   #30
Car: 06 EB Evo IX
Fav Mod: Me
IWSTI Addict since: Sep 2006
I have 255s on my Evo with 5k miles on Rota Slips (17x8.5). So far they look like I've used 30-50% of its tire life. I have been to 1 road racing event and 1 quarter mile track day. They do extremely well after a couple of laps on the road course. 245/45 are too tall in my opinion.
I've read several threads and I can't quite understand if 255s on stock BBS would work on an 04 STI. I am picking up a 04 STI and I really want to keep using the same type of tires. The gold BBS rims are too hot to replace.
The car has STI springs and hardened strut tops.
H8rade is offline   Reply With Quote
