Old 09-26-2006, 06:40 PM   #31
Fav Mod: JDM STi Performance Muffler
IWSTI Addict since: Mar 2004
Originally Posted by Huy
Eek! Don't stress me out more than i already am! I honestly hope that isn't an issue. This was the offset i was recommended by Rays & the shop(s) i made enquiries through.
The 06 STI hub isn't any different to the 05 correct? Because i know a few guys running +52 with the same coils on their 06's without any hassles.
Lol...Only reason I suggested that was because I was unfamilar with how the Whitelines were shaped compared to the stock struts. If there's other people running similar setups you should be perfectly fine. Good luck, and I can't wait to see the wheels.
300hp@6000rpm is offline   Reply With Quote
Old 09-27-2006, 04:40 AM   #32
Wheel33tist Whore
IWSTI Addict since: Dec 2004
it's slightly different but not in any aspect that will effect wheel fitment.
if you've seen other guys running that offset with your same coilovers and similar size tires, you'll be fine.
Old 09-27-2006, 12:20 PM   #33
Car: 04 WRB/Gold
IWSTI Addict since: Feb 2005
ok guys i am planning on the the 18x8.5 44mm on my 04. i have just couple questions.
1. does anyone have pics of the gunmetal or ti gunmetal on sti's blue would be nice but any color would work.
2. i am going to be running RCE springs, ALK(comfort), RCE Non-lowering camber plates, 22mm F&R cusco sways, Rear group n hats. I think i will wrap the rims in a 235/40/18. do you guys think this is a good set up i do not want any rubing. i do not want to roll fenders or anything.
i think that the car will look great and handle great without any rubbing am i correct.
p.s pics of them would be great. i either want the ti- gunmetal or the gunmetal. thanks guys
Trum1982 is offline   Reply With Quote
Old 09-27-2006, 12:22 PM   #34
Wheel33tist Whore
since you have an 04 you may need to roll the rear fenders slightly to prevent rubbing but you should be ok after that.
Old 09-27-2006, 01:10 PM   #35
Fav Mod: Need a fender roller? PM me!
I don't think you'll have any issues with the set up you're going with. I had 235 but recently switched to a 245/40/18 and I'm on Tein Flex's (dropped pretty low) and don't have any rubbing issues. Of course, I'm also running -2.0 camber in the rear.
adesso is offline   Reply With Quote
Old 09-27-2006, 01:11 PM   #36
Wheel33tist Whore
are you running a my04 or my05?
Old 09-27-2006, 01:14 PM   #37
2004 Ftw!
Old 09-27-2006, 01:15 PM   #38
Wheel33tist Whore
what size wheel were you running the 235/40s with?
Old 09-27-2006, 01:16 PM   #39
18x8.5
Old 09-27-2006, 01:17 PM   #40
Wheel33tist Whore
Offset?
Old 09-27-2006, 01:19 PM   #41
Old 09-27-2006, 01:21 PM   #42
Wheel33tist Whore
that's where the issue lies, him running a 4mm lower offset would be similar to you running a 10mm wider tire on your wheels.
i stand by my earlier comment where a baseball bat or a fender roller may be needed.
Old 09-27-2006, 01:27 PM   #43
< See my profile to left... (Favorite Mod)
Defintely finding the right offset is the key to prevent from running into problems. So I concur. I have seen other 04's running a CE28N in 18x85 fitment with no rubbing issues, but I don't know what the offset is for them.
To add insult to injury, I just recently rolled some fenders on another 04 this past weekend. He was running SSR SP1 Professors (18x8.5 with a +47 offset) and they were rubbing his 245/40/18 KDW's pretty bad. I wouldn't have even driven the 20miles he did to have his fenders rolled, they were that bad.
Old 09-27-2006, 01:29 PM   #44
Wheel33tist Whore
PM me, i'm interested in that fender roller of yours.
Old 09-27-2006, 01:41 PM   #45
You have PM
