Old 09-19-2006, 09:14 AM   #1
Car: white 04 wrx sti
IWSTI Addict since: Jul 2006
Default Wheel rubbing issues on Lowered 04 STI
Hey guys I hope someone out there can help me with my problem. My problem/question is as follows: I am having some rubbing issues with my 04 STI when I turn sharply to the left or right. I lowered my car with Tein Tech S Springs and Im still running stock BBS rims. I ran the car for 6 months with no rubbing problems until I replaced my Tires with BFGoodrich g-Force T/A KDW 2. size: (225/45/R17). The rubbing is coming from the front and I think the front wheels are rubbing the inner fender lining. Has anyone else had this problem and how did you fix it. I think 5mm spacers will fix the problem. Am I correct or is there something Im missing.
Thanks for the help.
RS25Tuner is offline   Reply With Quote
Old 09-19-2006, 09:45 AM   #2
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (53)
First thing would be to get some better springs that don't lower the car so much.
that's really about it.
Turninconcepts.com is online now   Reply With Quote
Old 09-20-2006, 06:34 AM   #3
Default Springs?
Which springs would you sujest?
Old 09-20-2006, 07:18 AM   #4
Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
IWSTI Addict since: Apr 2006
RCE, or STi pinks...
Old 09-20-2006, 08:01 PM   #5
Car: 04 subaru STI
IWSTI Addict since: Mar 2006
GF's or even the DF's
Scubbie04 is offline   Reply With Quote
Old 09-20-2006, 08:07 PM   #6
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
IWSTI Addict since: Jul 2004
STi pinks, RCE springs that will be coming out soon, or the Prodrive springs
Old 09-20-2006, 09:02 PM   #7
Car: 2004 Subaru WRX STi
IWSTI Addict since: Oct 2003
Send a message via AIM to Flynlow
All you are probably rubbing is your inner plastic fender liner. Take a wheel off and take a look around. I had the same issue when I went with my new wheels. You never noticed it before for two reasons: One, your old tires were probably a little worn so they were smaller in diameter and two, the KDW are not only new, but may be a smidge larger overall. If I am right, all you have to do is remove or shave down a small portion that you are rubbing.
Flynlow is offline   Reply With Quote
Old 09-25-2006, 06:10 AM   #8
Default Any other thoughts
Thans guys. Any other thoughts. Will a spacer work for me or will it cause more problems.
