| | #46 |
| Junior STI Driver | me too.. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #47 |
| Senior STI Driver Car: 05 WRX STI Fav Mod: Just having an STI is good enough. Location: Central Florida Posts: 392
IWSTI Addict since: Jul 2005 Trader Rating: (0) | I guess I'll be getting some Falkens soon because I need new tires!!!! I'll be changing my spring from the Tanabes GF-210s to the new RCE's with top mounts so I just came up with some questions and concerns. -Since the car is going to be lowered and on stock BBS's wheels, what should be the tire size I should go with? -Since so many here are going a little wider for extra grip, wouldn't going wider have an effect on the speedometer, gas economy and performance because of weight and width? -Also wouldn't going wider cause flexing when turning hard? -Will there be rubbing issues if the car is lowered? -Why not stay with the stock tire size for the RT-615 (pros and cons)??? -Are these tires louder then the stockers when driving on them? -How long do they last comapred to the stockers? Thanks in advance.... |
| | #48 |
| STI Driver Car: 06 Subaru WRX STI Fav Mod: I LOVE THEM ALL Location: Orange Posts: 241
IWSTI Addict since: Jul 2005 Trader Rating: (0) | I dont understand why going wider on stock rims can help that much, it only makes sense that wider on a stock rim would just make the tire flex more. I dont see how any tire can be better then the stock one which is the tire that the car was tested with and it was setup for our suspensions spring loads. I maybe wrong but thats just what makes sense to me. |
| | #49 | |
| Spec C Club Car: 06 white w/gold STi Fav Mod: gt40r Location: Orange, CA Posts: 1,223
IWSTI Addict since: Apr 2005 Trader Rating: (6) | Quote:
"wider is better" | |
| | #50 |
| Professional STI Racer Car: 05 STi OBP Fav Mod: Data Acq System Location: Warren, Michigan Posts: 798
IWSTI Addict since: Jul 2006 Trader Rating: (1) | Well going wider on a stock rim doesn't mean you are going to flex more. You have a wider contact patch, which will give more lateral force and maybe more flex. In the end all you care about is better handling and not busting stuff up. Wider tires will give you better performance (keeping everything else equal). The reason subaru uses 225's I think is because of weight, cost and clearences. I think the stock Bridgestones are sick and might be better than wider Azenis, but honestly the difference in lap times is probably nothing and the difference in the price is A LOT!!!! I just want to have fun with my car on the track and cheaper tires will allow me more of this. |
| | #51 | |
| Authorized Vendor
Car: 05 PSM Stage 4 Fav Mod: Pro-Tune Location: Big D Posts: 1,782
IWSTI Addict since: Apr 2005 Trader Rating: (17) | Quote:
| | #52 | |
IWSTI Addict since: Jul 2005 Trader Rating: (0) | Quote:
| | #53 | |
| S204 Racer Car: RIP 02 WRX Fav Mod: 2004 Aspen White WRX STi Location: Cincinnati Posts: 3,614
IWSTI Addict since: Dec 2005 Trader Rating: (1) | Quote:
2) Width doesn't affect spedo. Economy will go down by .05 mpg. Performance will be increased. 3) To a degree, but if you're going to be competing, you want all the grip you can get. 4) Not with 225s. 5) Pros: (Better) Fit and (Lower)Price. Cons: Less grip than 245/255/275s. 6) Possibly. The STi isn't that quiet inside to begin with. This shouldn't be a make/break factor, IMO. If it is, don't buy either tire due to the stiff sidewalls and tread pattern. 7) Depends on driving style, completely. | |
| | #54 |
| Amateur STI Driver | I picked up my car that I left at my friends house and drove home. It happens to be up in the mountains. I'm going at a pretty good clip and notice that the car is moving around a bit more than normal but still handling well. I reach the gas station at the bottom of the mountain and check tire pressures of the RE-070s and they are below 15 psi. If you look at them, the look like they're a little low but not that low. The RE-070s are stiff. The RT-615s are definitely not as stiff. I have the RT-215s, RT-615s and Hankook RS-2s for my autox Civic and the RT-215s are by far the stiffest tire. The RS-2s and the RT-615s are close with the RS-2s being slightly stiffer. If money was no object, I'd be running the Yokohama AD-07s but since it is, I ordered a set of the RS-2s. I went with the RS-2s for two reasons. They handle heat better and had the slightly stiffer sidewalls. But here's the kicker. I could have easily have gone with the RT-615s because of it's wider tread, better wet handling and the beefy tread on the shoulders. I think they're both really good tires and it just came down to the mood I was in, the day I ordered the tires. This past weekend, I won in my class autoxing my STS Civic. I had the RS-2s up front and the RT-615s on the back. If I had them reversed, I would have ordered the RT-615s. |
| | #55 | |
| | #58 |
| Spec C Club Car: 2008 Fitrari Red Fav Mod: Getting 40mpg Location: North Jersey Posts: 1,533
IWSTI Addict since: Jan 2004 Trader Rating: (8) | People who stay stock end up in second place. For all intents and purposes, wider IS better. The truth sometimes hurts. Go to ANY autocross and take equivalent drivers with equivalent cars and run one car with ~4 inches more rubber on it all around and tell me who pulls faster lap times. You can't beat physics with ignorance. 225 section width is fine for STIs that remain stock or slightly modified. Once you cross a certain threshold of power output and/or suspension setup and/or fear factor, they JUST will not suffice. I passed that threshold a looooong time ago. |
| | #59 | |
I'm not stock but don't have alot of power. I think that i might get these tires cause I haven't heard of anything better then stock tires other then these (Falkens RT-615) and they just are a little notch under the stockers. What tire size would you recommend if I have the stock rims and want some better performance? | |
| | #60 |
| Grassroots STI Racer | How do the RT-615s handle in the wet? How's the hydroplane resistance? Any info on how they are in colder weather/snow compared to the RE070s? I know it wouldn't be safe to run the RT-615s in snow, but in the unfortunate event that it inadvertently happened, how would they handle? This ad is not endorsed by this member. Please register or login to hide this ad. |
