| Lurker | I am thinking of getting wider tires when I replace my tires, probably some 235-45-17 Goodyear Eagle F1 GS-D3's. Anybody know if this will cause the speedo to be off? This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Wheel33tist Whore
Car: Aspen White GDF-D Fav Mod: Pastelito Racing / SFSOC Location: 0R!4ND0 Posts: 21,523
IWSTI Addict since: Dec 2004 Trader Rating: (7) | it will cause your speedo to be different then it is currently. it wasn't accurate in the first place. so a few more MPH isn't a problem. your speedo will still read faster than you're actually going. |
| | #3 |
| Spec C Club Car: 05 STi - Black Fav Mod: No Lien Location: Ontario, Canada Posts: 1,959
IWSTI Addict since: Mar 2006 Trader Rating: (2) | actually, you've got it backwards. The overall diameter is larger. Therefore, you'll be going faster than what your speedometer is telling you. ie speedo says 60mph - your true speed 61'ish mph |
| | #4 |
| Junior STI Driver Car: 05 Subaru WRX STi Fav Mod: SFSOC / Pastelito Racing Location: Coral Gables, FL Posts: 199
IWSTI Addict since: Mar 2005 Trader Rating: (0) | No, with the 235/45-17 tires the car will be doing about 77 mph when the speedo reads 80. The speedo will actually say you are going faster than you really are. With the stock tires the speedo would show 80 when you are actually going 76. The taller tire only changes the speedo by about 1 mph when the speedo says 80. What 05_GD7 is forgetting is the speedo is already off from the factory. |
| | #5 | |
| S204 Racer Car: '04.5 STi Fav Mod: Whiteline steering rack bushings Location: Montgomery, Al Posts: 3,077
IWSTI Addict since: Apr 2006 Trader Rating: (0) | Quote:
![]() I think the 235/45 would actually be closer than 225/45. I have a set of 3/4 worn 245/45's on my car right now and when I drive by the roadside radar detectors at 28 mph it reads 25 mph. I can't imagine how far off a worn out set of 225/45's must be. | |
| | #6 |
| Spec C Club | Use this tool to compare tire sizes, diameters, and affect on speedo: http://www.miata.net/garage/tirecalc.html |
| | #7 | |
IWSTI Addict since: Mar 2006 Trader Rating: (2) | Quote:
But I digress for a second. Lets just ASSUME that the speedo with stock tires is accurate. Larger overall diameter equates to a taller gear. Which means you travel farther with every rotation of the tire than you did before. So instead of going, for example, 5 feet per rotation, you are in fact, going 6 feet, while your car still thinks it has only gone 5 feet. Therefore, with the sizes that the original poster is proposing, he will be actaully travelling 61 mph, while his speedo says 60. | |
| | #9 | |
| Platinum Member | Quote:
No one is disputing the concept. It is just that the factory speedo reads high by ~5%, with a taller tire you just end up making it "less incorrect..." | |
| | #10 | |
I think GPS is probably the only accurate way to measure this. | |
| | #11 |
| S204 Racer | We've beaten it to death. Search for "speedo error" or "speedometer error". This has been done over and over. This ad is not endorsed by this member. Please register or login to hide this ad. |
