Old 06-27-2006, 04:58 PM   #1
IWSTI Addict since: Nov 2003
Default Wheel Bearing Issue?
My 04 sti have 60000km on it. I am having a problem, When i am moving below 25 MPH and mostly when rolling to a stop i can hear some kind of rotational noise that sounds like it is coming from the wheels or the rear diff, It sounds like the wheel is not spinning smoothly or driveshafts. Anyone have the same problem? Anyone know is the wheel bearing or the driveshaft problem for help.
edykh is offline   Reply With Quote
Old 06-27-2006, 07:16 PM   #2
Car: Bugeyes forever!
IWSTI Addict since: Apr 2004
Wheel bearings usually make themselves noticeable when moving at speed. I have heard brake problems make noises like you are describing. Check your brake pads out, it could be the feeler starting to rub on the rotor.
Ver7wannabe is offline   Reply With Quote
Old 06-27-2006, 08:44 PM   #3
I just put a Hake hps 2months ago with 1 lapping day. So how do i check is the brake padrub on the rotor?
Old 06-28-2006, 05:21 AM   #4
Just look at the amount of pad that is left.
