| | #31 |
| Senior STI Driver | do they come with a free set of chop sticks?? This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #32 | |
| S204 Racer Car: Solo II, WRC Location: Overland Park, KS Posts: 2,776
IWSTI Addict since: Oct 2002 Trader Rating: (1) | Quote:
- sidewall deflection among tires isn't a good comparison. If you picked the best handling 45 series to go on a 17 vs. the best handling 30-35 series for a 18-19, I doubt you'd see any difference in deflection alone. However, what type of tire can you get in that small of a series....probably not something that will match the compound you'd get in a higher profile tire. - I don't quite understand that sidewall bulge debate as described. That's the first I've ever heard someone describe something like that and I think the differences you are talking about are so minimal, no one would ever know it. That's kinda like saying a larger rolling diameter tire has a larger contact patch because you are resting on a larger angular area....we're talking sq mm's here! I think the more significant difference which works opposite of what you are talking about is that when you are at a 30-35 series tire, you are stuck with the correct series of tire. However, with a higher profile, I can throw a 225 series set of Azenis on a wheel sized for a 205 series. With any old tire, this would be a very poor practice, excess bulge all around, rolling over on the sidewall and so on. With a tire like the Azenis or RE070, the sidewall is stiff enough to make this a great practice. These aren't just my feelings....look around the staging areas at the next local Solo II..... - Weight AND size both matter. A 17" 20lb wheel will not accelerate the same as a 19" 20lb wheel. The mass moment of inertia comes into play. Easy way to think of this....which would be easier to spin in your hand: a 10lb weight sitting in your palm or a 12" long stick with 2 5lb weights at the ends, held in the middle? The further away from the axis of rotation that you move the mass, the harder it is to rotate. For outright performance, I think the best case is still to have the smallest, lightest, widest rim you can find and get a tire that is made to race, which usually leads to a Hoosier or Kumho with a higher profile. Try to match stock rolling diameter for top speed applications, stay as small as possible for max acceleation apps. | |
| | #34 |
| Spec C Club Fav Mod: Stealth mode Location: Eugene, Oregon Posts: 1,154
IWSTI Addict since: Nov 2003 Trader Rating: (2) | The contact patch increases in length with a larger diameter wheel, improving braking and acceleration grip. But you gotta have brakes able to handle the extra torque load and the power to make them move. |
| | #35 | |
IWSTI Addict since: Nov 2003 Trader Rating: (2) | Quote:
| | #36 |
IWSTI Addict since: Oct 2002 Trader Rating: (1) | Not in the case of serious tires.....such as the Azenis or RE070s. Heck, the RE070s weigh as much as the BBSs! Contact patch area increase due to larger rolling diameter is another moot point. If it was the difference between a 6" diameter and an 18" diameter, that's one thing.....17s to 18s or 19s.....call it negligible at best. And that's real rolling diameter change, not just plus sizing the tire/wheel package. The real gain in footprint size is a real addition of width. |
| | #37 | |
| Spec C Club Car: Motorcycles Fav Mod: Student Location: Western Washington Posts: 1,929
IWSTI Addict since: Oct 2003 Trader Rating: (0) | Quote:
That's what im saying. Larger rims just mean longer spokes... the majority of the weight of the rim is still there.... but with the tire (assuming you maintain the same overall diameter), getting a larger rim means you're cutting out a lot of that heavy sidewall rubber.... I'd say it's probably close in terms or weight... or at least a wash. | |
| | #38 |
IWSTI Addict since: Oct 2002 Trader Rating: (1) | Yeah, you're right there. Even if it was a wash, the weight is moving from that band a little closer to the center of the wheel. The only thing I keep seeing though....when you are down to these small profile tires (and we're still trying to maximize performance), how great of a tire can you get? What's the best handling, soft compound 35 series tire out there? (Really asking here....never really looked too hard). |
| | #39 | ||||
| Junior STI Driver | Quote:
| | #40 |
IWSTI Addict since: Oct 2002 Trader Rating: (1) | Good discussion..and I know we could discuss all of this for weeks. I'm glad we could discuss and agree to disagree. Every little change we've talked about has a differing degree to it's impact (225 tread comparison, mass moment...) but I keep thinking back to the original question posed...for performance sake, would you go to a 19 for that reason alone. I can't say that's a right answer at all. The only claim to back that up would be your last statement above, to which I say look around here.... http://www.scca.org/amateur/solo2/na...lts/index.html Real world (No F1, WRC..), street cars, street legal tires....and you'll see a few things sticking out...the tire brands. Hoosier and Kuhmo fight it out every year. They both have one thing in common though....the tires they make for this competition aren't in rubber band sizes. That tells me something. If there was a sure-thing advantage to having as large of a wheel and as small of a sidewall, I'd think they'd be all over it. I'm not saying a low profile tire isn't great for handling on the street...I just don't think that's the best answer. Same model of tire with profile change from 17" to 19" wheel, I agree with you completely, the smaller profile would be a better performer. Same 17" wheel, add a great tire only and I'll bet you can have better handling for a lower overall cost. Good discussion! |
| | #41 | |||
But money aside....give me the 19's AND suspension. | |||
| | #42 |
| Junior STI Driver | ehh - as far as im concerned anytime you go up in size you go up in WEIGHT, if the material is the same (id assume so) anyway. and we all know the unsprung weight of a wheel is going to affect handling. its cool if you want the 'look' but i am fairly sure the suspension/diffs were engineered for 17's and you may take a negative hit on performance, possibly voiding warranty or damaging parts. but if you arent road racing/drag racing or worried about 1/10's of seconds on a track i wouldnt worry about it. i personally wouldnt go higher than an 18 on a small car like the sti though, i had 32" mud tires on my xterra and it killed the ABS system - it just wouldnt work - only 3 inches taller than stock. dealer didnt know what to do. just my opinion. i am personally going for performance. i like the rally look anyway. |
| | #43 |
IWSTI Addict since: Oct 2003 Trader Rating: (0) | Bigger rims and tires with a smaller sidewall - not necessarily any heavier at all, and because you're keeping a very near-stock overall diameter, components like speedometer and brakes shouldn't feel any difference. This ad is not endorsed by this member. Please register or login to hide this ad. |
