Old 05-14-2008, 05:54 AM   #31
Wheel33tist Whore
Default Re: largest rubber on stock rims?
i'd go with a 245/40/17 RE01R if i were buying new tires for my Stock BBS wheels.
Old 05-14-2008, 06:23 AM   #32
Car: Silver 04 EDM STi
Fav Mod: none yet :)
Falken is not that easy to get over here, I was going to go with the RE01-R's just hadn't decided on the size yet. I have now
roydriessens is offline   Reply With Quote
Old 05-14-2008, 09:42 AM   #33
Fav Mod: Nintendo Decal
Originally Posted by B4RSTiwsnc View Post
I ran 245/45 on my 05
...even lowered? Did you have any rubbing with spirited driving or autox days?
unrequited is offline   Reply With Quote
Old 05-14-2008, 09:45 AM   #34
Fav Mod: Motor Mounts
That will depend on a number of factors.
Rim offset...
How low...
Rolled or not rolled rear fender...
I ran 245/45's on the stock rims but was not lowered. Understand the rubbing issues will be in the back most likely. The front fenders are cake...
Old 05-14-2008, 10:55 AM   #35
I'm stock but thinking of jdm pinks which aren't too much lower. I was just concerned about rubbing under load like hard turns or braking.
Old 05-14-2008, 12:29 PM   #36
If you roll your rear fender and get -1 - -1.5 degrees camber...I think it will work.
Old 05-14-2008, 12:43 PM   #37
Car: UGM 07 STI
Fav Mod: Learning to drive better
Send a message via AIM to Urban07STI
Not to get too off topic, but I noticed on Th3Clap's blog that 255/40/17 tires are an option for a near stock suspension. Would using the RT-615's in that size fit correctly on the stock 8 inch BBS rim? Just looking to plan ahead for summer replacements. Would be nice to get good looking wide tire and not break the bank.
Urban07STI is offline   Reply With Quote
Old 05-14-2008, 02:32 PM   #38
HowTo Contributor
Fav Mod: Cobb Stg 2 - Wrapped DP
Will be on 07 wheels, so 9" wide i believe, stock suspension for now, but when i buy tires the car may be lowered on RCE yellows.... any rubbing ya think?
Old 05-14-2008, 02:40 PM   #39
Wheel33tist Whore
07s are 8" wide.
Old 05-14-2008, 02:47 PM   #40
Yeah, 07's are 8" wide. Not even 08 STi have 9" wide rims. You may experence rubbing...the question is are you willing to roll your fenders? If not stick to sizes < 255's on lowered suspensions...even then 245's on lowered suspension may rub without changing camber or rolling.
Old 05-14-2008, 04:14 PM   #41
HowTo Contributor
07s are 8" wide.
my mistake guys, i forgot its 7.5" for 04s and 8" for 05+.... i WANT 9" for later
I am willing to roll or trim the fenders, since i would like a more aggressive wheel and suspension combo later...
RCE Yellows and RCE camber plates (lowering or non, i dunno)
8" BBS - 245/40/17.... if they're gonna rub, any idea on how bad? like i said, im willing to do some extra work since i'll have to later
Old 05-14-2008, 07:11 PM   #42
Car: '07 Obsidian Black
Fav Mod: Stage 2 + Protune
Ok so stock suspension and stock BBS on 06/07 - 255's will be ok? TIA!
karleric is offline   Reply With Quote
Old 05-14-2008, 08:06 PM   #43
Maybe you didnt see my post earlier...
Ive run 275/40 V710's on 8" wide rubber on stock suspension. I had to roll my rear fender and add a 3mm spacer. Fronts...nothing. Obviously a 255 < 275. Given that factor...I am in an 04 STi which adds even less rear clearance. PM me if you need more info....
Old 05-14-2008, 08:36 PM   #44
Car: 05 CGM STi
Right now I have 245/40 RE01R on my 05 STi with stock bbs wheels and love them. My suspension is stock as far as ride height but will be installing RCE yellows when I get the time...
y WOULDNT u? is offline   Reply With Quote
Old 05-14-2008, 09:26 PM   #45
HowTo Contributor
i'll most likely be opting for the 245/40 re-01r next time around, or the 245/45 615s
