Old 06-15-2005, 06:31 PM   #1
Car: 2006 Subaru
Fav Mod: JDM "Baby In Car"
IWSTI Addict since: Mar 2005
Default Wheels for STi & Evo - mmm.....help!?
My friend and I are trying to get some wheels together....
Probably not the same wheels, but, jsut wondering........
if any dark-colored (e.g, black, dark grey) rims that would fit both the 04' STi and the 04' EVO VIII.
I think we will check out the tires after looking at the rims.
We just have different offsets, right?
Help the noobs. Thanks.
iTSTi is offline   Reply With Quote
Old 06-15-2005, 08:00 PM   #2
IWSTI Addict since: May 2004
Trader Rating: (71)
Send a message via AIM to Paperchasin
the evo uses 5x114.3 while the 04 sti uses 5x100...that alone could put u SOL as far as getting the same wheels goes...and yes, u are correct, evos can run some really low offsets...lowest offset ive ever run was a +38 and it rubbed like no other...
Paperchasin is offline   Reply With Quote
Old 06-15-2005, 08:53 PM   #3
www.Subie.tv is niiice
IWSTI Addict since: Aug 2003
BBS REs
edit: yeah 04 is different offset than 05 which shares the same lug pattern as the EVO
Old 06-15-2005, 09:27 PM   #4
Car: 2006 Subaru
Thanks
I was looking at the 5 Zigen GN+ Pro Racer Light Weight JDM Wheels 18" x 8.5". They look kidna nice.....so i was thinking getting these ones.
Old 06-18-2005, 03:45 PM   #5
Actually drives an STi
i'm running a +35 offset 19x8.5 w/ 235/35/19 rubber on my 04 sti. no rubbing...
anyway u can get any set of volks for both the evo and the sti..
u should check out le28n's look great on both the evo and the sti
read if ur interested in a set.
http://imprezawrxsti.com/forums/showthread.php?t=27236
EvoSpecVIII is offline   Reply With Quote
Old 06-18-2005, 05:01 PM   #6
retired mod
Car: 99 WRX STi V5
Fav Mod: JDM Air Freshener
IWSTI Addict since: Apr 2003
Send a message via AIM to eatV8 Send a message via MSN to eatV8
iTSTi, you should know better by now. I got the hookups for you on this one aswell Well at least can see what prices I can do for you.
eatV8 is offline   Reply With Quote
