Old 04-20-2005, 08:41 AM   #1
Fav Mod: Motor Mounts
IWSTI Addict since: Oct 2004
Default Will 245/45/17 fit my 7.5" 04 BBS?
Will just about any 245/45/17 fit my 7.5" 04 STi BBS rim?
Thanks in advance for you help.
Pauly
Old 04-20-2005, 09:36 AM   #2
Car: autocross, road racing, Bike cruising
Fav Mod: student/design engineer
IWSTI Addict since: Dec 2002
Send a message via AIM to FasStAsS_sTi
yes it will , do sum searching before asking repeatious questions =)
FasStAsS_sTi is offline   Reply With Quote
Old 04-20-2005, 10:01 AM   #3
Thank you. I searched and some said yes and others said no. So im sorry if its been asked too many times.
Old 04-20-2005, 10:20 AM   #4
IWSTI Addict since: Apr 2003
What tires you are putting on? Read the technical data about minimal wheel width you can put on a specific tire. For example, Toyo recommends at least 8 inch rims for 245/45/17 tires.
vz64 is offline   Reply With Quote
Old 04-20-2005, 10:56 AM   #5
Pauly, one more thing - 245/45/17 will be +18mm off of stock diameter, which is a bit too much. I decided to go with 245/40/17 and it is only -6mm off of stockies.
Old 04-20-2005, 11:33 AM   #6
Supposedly the minimum width spec for this tire is 7.5"...
Im looking at some Dunlop SP Sports in that exact dimension, looks like a good price and my tires are nearly toast from this season’s autox. If they fit...I will get them but what you are talking about is the offset will be + 18mm off? Im not the guru on this stuff at all...or 18mm taller than stock? Do you suspect that I will have rubbing issues with this particular wheel?
Thanks again.
Old 04-20-2005, 12:35 PM   #7
I meant they will be 18mm taller, so your speedo will be off. I am not sure if you will have rubbing issues, but I don't remember anybody getting rubbing with 245/45/17.
