Old 04-15-2005, 11:01 AM   #1
Car: Blue 04 STi
Default Need new front pads at 13,000 miles?
THis is what my mechanic said. I still don't believe it. I do not autox and only drive the car moderately hard. If I really do need new pads, should I go with the OEM again? Best price I could find is $215 on the internet. Any other recommended pads for the summer?
oogster is offline   Reply With Quote
Old 04-15-2005, 12:04 PM   #2
Car: 06 acura tsx
Fav Mod: soon to come
Send a message via AIM to whitson01 Send a message via Yahoo to whitson01
my buddy has 30k miles on his sti and claims he hasnt changed the pads yet!!??
so i dont know.. i wouldnt go with oem.. theres all kinds of pads to choose from.. i havent decided my self which ones to go with..
whitson01 is offline   Reply With Quote
Old 04-15-2005, 12:30 PM   #3
Spiteful Old Codger
Well… how much wear is left on the pads? My OEM pads are at about 6mm, and that’s with about 100 autoX runs, 4 lapping sessions and about 19K total miles. I would expect these pads to be good for close to 40K miles of reasonable street driving.
You can definitely do better than the OEM’s in terms of performance, but there are a number of variables to take into consideration: Noise, dust, low temperature grip, high temperature fade resistance, feel, etc. Depending on your objectives, you may want to swap two sets back and forth.
Old 04-16-2005, 04:33 AM   #4
Car: Blue 04 STi
What are some different brands of pads?
Old 04-16-2005, 06:02 AM   #5
TRM
uh, whut?
Fav Mod: wdb
Send a message via Yahoo to TRM
the OE pads brand new are just over 9mm thick.
you should check the pads yourself. once you get down to about 3mm it's probably time to change them.
TRM is offline   Reply With Quote
Old 04-16-2005, 06:13 AM   #6
Get a second opinion (or do as TRM suggested). I think the only way you'd have worn the stock pads that fast is with regular auto-x or street driving in a manner which you would no longer have a driver's license.
Boxer is offline   Reply With Quote
Old 04-16-2005, 10:38 AM   #7
Spiteful Old Codger
I’m using Porterfield R-4’s for the racing season and swapping back to OEM in November.
You can see the remaining pad thickness pretty easily by just looking in under the caliper – you can’t actually measure it without taking the pad out, but you’ll get a good idea of what you have by just shining a light in there. You could also look at how far the "squealer feelers" are away from the rotors.
