| STI Driver | I've been straying away from even attempting this but I can't hold back anymore. I've read tons of stuff, including the blog but I think I still need to be pointed towards exactly which coilovers would suit me best, which width tires for this size wheel and who to trust with the install/modifications. This would be street only, and I would like a bit softer spring for that. I live in NY, near NYC but I don't know of any shops that can/are known to tackle a job like this. Since the 05+ fenders don't get "rolled", more like reconstructed I want a reputable shop. Ideas? This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| aka: jnprn2003
Car: 07 STi, 07 Speed 3.. Fav Mod: EFI Logics tunage Location: The Ocean State Posts: 2,408
IWSTI Addict since: Feb 2007 Trader Rating: (13) | Try XXTuning in CT. A few hours from you that can tackle your job. XX Tuning Connecticut DYNO Connecticut facility - Dyno Proven Subaru WRX STi Forester XT Legacy GT Performance Parts - Connecticut AWD Dyno tuning Facility DynaPack Mustang Dyno dynamometer serving Connecticut New York Massachusetts CT NY MA - northe Also try Den Sport Garage in MA. DSG - DENT Sport Garage Joe |
| | #3 |
| Wheel33tist Whore
Car: Aspen White GDF-D Fav Mod: Pastelito Racing / SFSOC Location: 0R!4ND0 Posts: 21,448
IWSTI Addict since: Dec 2004 Trader Rating: (7) | alright. what camber are you willing to run? what's your budget? have you already bought the wheels? (Hopefully no). main reason for the wheels? Looks/Performance/both (one more than the other)? desired Tire sizes? desired uses for said wheels? # of street miles driven and desired tire life? you can PM the budget info if you want to keep it off the boards. I can help you pick out a setup that will meet your needs of both looks, performance and budget but I need some more info. |
| | #4 |
| Amateur STI Driver Car: 07 Satin White Pearl Fav Mod: Everything! Location: Westchester NY Posts: 9
IWSTI Addict since: Jun 2007 Trader Rating: (0) | I have an 07 STi. I'm actually leaning towards the same thing. But i'm also leaning towards Fender Flareds, so if that will be the case...18x10.5 with 20-25 offset...still debating that. The Wheels would be the SSR MS1's. This will be agressive, i know...but a friend of mine owns a reputable bodyshop so cost of fender work isnt an issue. The issue is the clearance from the inner part of the rim from the strut. Thats my issue. I love the Time Attack look, also ive been in the German scene before i had my STi so i always Ran low offets and pulled fenders. Pay to play i guess. So what you think Clap? |
| | #5 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | I think you need to PM instead of Jacking this guys thread. |
| | #6 |
| STI Driver | I'll post here so others can have the info easily if they end up in the same situation. what camber are you willing to run? Whatever is needed. As far as looks go I would want it to be negative. what's your budget? Wheels are priced already, but I'd like to get coilovers & camber plates for around ~1500 if possible. have you already bought the wheels? (Hopefully no). No, they are only making 15 sets and I have to put my order in now to get them in 4 weeks. main reason for the wheels? Looks/Performance/both (one more than the other)? In this case, looks then performance desired Tire sizes? Don't have one, but I do not like the stretched tire look so I guess 245 is the minimum. desired uses for said wheels? Street only, daily driving. # of street miles driven and desired tire life? 100% street, tire life itself isnt a big concern but Im sure ill end up with 615's like everyone else. |
| | #7 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | to run that offset wheel you're going to need to run alot of camber. upwards for -3.0 front and -2.5 rear. and you'll need to modify the rear fenders too. as for coilovers you could buy used and save a good bit of money and still get a quality setup with plates front and rear. you see this? How To: Properly Modify 05+ GD STi Rear Fenders » t3h_Clap’s Wheel33tist Blog |
| | #8 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | tire size is going to be dictated by the amount of fender mods you run, amount of camber you run and the ride height. who's car are you trying to emulate here? that +27mm is pretty low for a 9.5" wheel generally the 05 STi's prefer closer to +35mm. what wheels are you looking at getting? |
| | #9 |
| STI Driver | Yeah I read that, which is why I was a bit weary of who to let do this to my car. It looks like a lot of work that could go wrong. I agree 27 is pretty nuts, but it's the only offset this wheel comes in. Set up on an 06, Looks like he got them to fit pretty easily -> enkie NT03+M 18X9 1/2 new tires! - NASIOC |
| | #11 |
| Spec C Club
Car: 02 wrx bastard child Fav Mod: 5x114.3 swap Location: copperas cove TX Posts: 1,234
IWSTI Addict since: Oct 2007 Trader Rating: (0) | +27 nt03 +m will not fit, you need about a 15mm spacer in the front to clear brembos. I run them in +40 with a 10mm front spacer and the +27 have even less brake clearance. |
| | #14 |
| STI Driver | I don't want to stray off the original topic I created but if this is going to be pretty rough to do I may go with this instead. ![]() ![]() The Advan RZ - but I am unsure to the size for this. Would I be better off with: 18x8.5 +31 or 18x9 +35? |
| | #15 |
| Spec C Club
IWSTI Addict since: Oct 2007 Trader Rating: (0) | 18x9 +35 is an easy fit in the rz This ad is not endorsed by this member. Please register or login to hide this ad. |
