Old 07-18-2008, 04:29 PM   #1
Car: 04 Aspen White STi
Fav Mod: exhaust powered intake
Default Alignment or Hub?
So last night I traded my Rotas for OEM BBS with Dunlop SP sport maxx tires (225 45 17) and I noticed a noise from 25mph up that sounds like tire roar, but I know the 04's have bad hub bearings. My rota's never made this noise until I put the BBS/dunlop's on. My alignment is off and I have to use a bit of force to keep it straight. My ? is this the hub bearing (overnight) or alignment out of wack? thanks
B4RSTiwsnc is offline   Reply With Quote
Old 07-19-2008, 07:26 AM   #2
Default Re: Alignment or Hub?
anyone?
Old 07-19-2008, 05:41 PM   #3
Car: 05 OBP Sti
sounds like the tires to me
Convoy is offline   Reply With Quote
Old 07-19-2008, 05:49 PM   #4
Car: '05 CGM
Fav Mod: HPDEs
Probably just tire noise that's coming from two sources.
1. Bad alignment (which you should get fixed asap).
2. Putting different tires on the car. They probably have a bit of a wear pattern in them which is different than the wear pattern for your car, especially with the bad alignment. So until the new tires start to acclimate themselves to your car, you'll have higher than normal noise levels.
Gary
