Old 07-12-2008, 02:58 PM   #1
Car: l2005 CGM WRX STi
Fav Mod: Cobb AP
Default Wheel GURU's HELP!
I have someone with a set of 18" gramlight 57s Maxximum (225/40/18)
And wondered if they would fit on my sti, or clear the brembo calipers. How much of a preformance loss would it be also? The wheels aren't as wide and the tires arent' nearly what the Potenza's are. Any info would be great!
thanks
cam
infected07 is offline   Reply With Quote
Old 07-12-2008, 05:00 PM   #2
Muller Chevrolet
Fav Mod: a new 08 STi
Default Re: Wheel GURU's HELP!
what's the offset and bolt pattern? if they are smaller than stock, then don't put them on.
Old 07-12-2008, 08:12 PM   #3
Fav Mod: Cobb AP
I'm not sure the offset... I think there 40. I know the bolt pattern is the same, 5x114.3. Why shouldn't I put them on if there smaller than stock? A free set of Rays Gramlights is a pretty sick deal, I just wanted to know if they will fit alright and clear everything.
Old 07-12-2008, 08:31 PM   #4
Reasonable
Fav Mod: correct grammar
If they're free, why not just test fit them?
Also, please post wheel and tire questions in the Wheel and Tire forum, not the General forum. That should be obvious.
Old 07-12-2008, 08:32 PM   #5
Fav Mod: Cobb AP
Cause I dont have a garage to test fit right now, and I figured one of the wheel guru's would just know
Yeah I just figured it was a general question, i'm not good at navigating this site yet.
thanks.
Old 07-13-2008, 06:01 AM   #6
Wheel33tist Whore
my guess is they are 18x7.5"
the offset is on the back of the wheel on the mount face.
they are either +33mm, +43mm or +48mm.
the +33mm will clear brembos but the offset is really low, especially for a 7.5" wheel and you may have fender issues depending on your ride height, suspension and alignment.
the +43mm will clear as well and is the correct offset for the MY05 STi.
the +48mm will not clear brembos without a spacer, and running a spacer on stock wheel studs is not recommended.
you can always buy new tires for it and if they are free you can sell them later on.
once you know the offset we'll know if they'll work, otherwise it's all a guess.
Old 07-13-2008, 08:25 AM   #7
Fav Mod: Cobb AP
Okay! Thanks for the info. I've set up an apt. with my buddy for wednesday to test fit them in his garage. I'm on stock suspension still so I cant see them rubbing. 7.5" seems so small for such a high end wheel... im supprised they didn't order them with a more agressive stance. Oh well, if they fit I will be happy and take some pics to let you all know.
-cam
Old 07-13-2008, 09:42 AM   #8
Wheel33tist Whore
you said they are free?
if you're buying them you should buy a wider wheel.
the 07 STi looks much better with an 18x8.5 +45mm and a 235/40/18 tire or even a 245/35/18 tire.
going down to a 7.5" wheel and cheaper tires will reduce performance.
Old 07-13-2008, 12:20 PM   #9
Car: 04 sti
Fav Mod: enginuity tuned
18x8.5 ftw
going to a 7.5" wheel is a step back seeing as how the oem bbs are 8" wide.
Old 07-14-2008, 01:06 AM   #10
Fav Mod: Cobb AP
Originally Posted by nhat View Post
18x8.5 ftw
I realize that guys, its hard to say becuase the stock BBS are not bad, especially wrapped in the potenza's. I know a wider wheel is more agressive and would look much better... but gunblue 18" Rays gramlights will look amazing on my 07 SWP. I'm trying to justify the looks (besides rim width) over the stock BBS. I think it would look killer, but I hate that im losing preformance. I'd be going to a Khumo tire, from bridgestone but I think the wheels would look hot for summer and use the stock BBS for winter (with preformances winter ofcoarse). I am just hoping the change isn't too noticable... I guess if I got them (not free) but a killer price, I could always clean them up and sell them. they were kurbed quite bad but its only 140 per wheel for a brand new finish again. How much do you think this things are worth on the market? maybe find myself a cheaper 18 x 8.5 like Enkei's or somthing. RPF1's are nice.
Old 07-14-2008, 04:37 AM   #11
Reasonable
$140 a wheel to fix and refinish them? Walk away from whatever shop you're talking to and either A) find a new shop, or B) find a better set of wheels. Preferably B, but that's just an opinion.
Old 07-14-2008, 05:23 AM   #12
Wheel33tist Whore
so $140 per wheel to refinish + how ever much they cost?
the gramLight 57Maximums are not $400 a wheel to start with.
i agree the gunblue will look great on your car, but do not make the mistake of buying wheels that "need repair".
there are alot of quality vendors that can find a wheel that will fit a reasonable budget.
Old 07-14-2008, 06:00 AM   #13
Fav Mod: The Newest One!
I just put on a set of 18x8.5 57Mximums on my car 2 weeks ago. While they were/are heavier (21lbs) than the stock BBS (19.2lbs) and my Rota Tarmac 3s (20.1lbs), They look beautiful in comparison. As far as performance goes. If you are worried about the tires, look into a set of Falken Azenis 615. If you dont track your car, I dont think you will notice a difference in performance.
As far as the weight goes. I took off the Tarmac 3s to put these on. While the Gram Lights are a better quality wheel, they did weigh .9lbs more. That said, the combo of the Gramlights with the lighter Falken tires is still lighter than the stock set up of the BBS and the RE070 tires by about .7lbs
I have found that it is the tire size that makes a big difference as far as performance goes. I am sure I may have lost a little bit of performance going to a heavier rim, but I havent noticed anything.
Question about 18s and performance (I did my HW and question still unanswered) - NASIOC
