Old 06-13-2008, 10:34 AM   #16
Wheel33tist Whore
Default Re: 2005 STI with 5x100
Originally Posted by rbento11 View Post
I bet the wheels are stamped 5x100 even though they are really 5x114.3. Definitely double check though.
bingo, the original mold was for a 5x100 and they simply drilled it out differently.
everything is golden.
you've got an 05 there.
also, early 05s had a metal coolant res.
Old 06-13-2008, 11:36 AM   #17
Car: The Vroom-mobile
Fav Mod: JDM Gears
learn something new everyday
Old 06-13-2008, 11:54 AM   #18
Car: 05 WRB STi
Fav Mod: PWT Points
05 metal coolant res FTW!
(i had to feel cool somehow)
Old 06-14-2008, 07:34 PM   #19
Car: 2005 WRB STI
Fav Mod: Fujitsubo exhaust
Update.
Picked the car up and had a closer look at the SSR rims. As already stated you can clearly see it says 5x100 cast into the outside rim...there was a sticker inside the rim showing it was 5x114.3...so I am all good No more worries.
And as a side not I took a closer look at my Work Emotion XD9 rims and cast into it's lip on the outside is 4x114.3 HAHAHA I mean you can clearly see it's a dual 5-bolt pattern.
Gixx6 is offline   Reply With Quote
Old 06-15-2008, 07:35 PM   #20
wdb
dances with roads
Another dead nuts sign that you have an '05; the extension over the rear wheel arches to allow for the '05's 1" wider rear track.
Old 06-16-2008, 10:05 AM   #21
Car: 04 WRB
Fav Mod: Greddy TI-C
on top of that, the interior cards have the entire arm rest in blue while that isn't the way on the 04's... the entire center console is different and steering wheel, even the seats are different
Old 06-16-2008, 11:01 AM   #22
Car: 05 Subaru WRX STi
Fav Mod: Bride Zeta III / Advan RGII >=)
When I had a set of GramLights 57F wheels, they too were stamped as 5x100, but were actually 5x114.3
SD 05 STi is offline   Reply With Quote
Old 06-16-2008, 01:17 PM   #23
Car: black 04 WRX STi
My 2004 (manufactured 11-03) came with a plastic coolant reservoir.
Walt is offline   Reply With Quote
Old 06-16-2008, 01:48 PM   #24
Fav Mod: JDM Gears
about the interior, all that can be changed, same with the fender flare for the 05's
Those would be "easy" changes.
