Old 06-10-2008, 10:23 AM   #1
Car: 07 GDB-G WRB STi
Fav Mod: shift knob
Default Widest tire on a stock 07 STi rim
What's the widest tire width I can fit on a stock 07 STi rim?
rs_wrx_sti is offline   Reply With Quote
Old 06-10-2008, 07:30 PM   #2
Car: 06 STI
Fav Mod: Ultimate Racing GT30R, Kartboy F+R shifter bushings
Default Re: Widest tire on a stock 07 STi rim
people put up to 275's fpr auto x'ing but for a street tire 255.
BlackedoutSTI is offline   Reply With Quote
Old 06-10-2008, 08:29 PM   #3
Car: OBP STi
Fav Mod: really quick left foot & anything made my TIC
Is there a reason you want to get the maximum width? I would stick to 245s on the stock wheels, unless you are competitively auto-xing. If you are road racing, definitely would not advise any size greater than 245 on stock wheels.
pharo is offline   Reply With Quote
Old 06-11-2008, 06:21 AM   #4
Wheel33tist Whore
Here's a good article on the topic.
How Wide of Tire can I Run on my 2005+ Subaru Impreza WRX STi on Stock Wheels? » t3h_Clap’s Wheel33tist Blog
either way I say go with a set of 245/40/17 RE01Rs and be set.
no worries of rubbing if you lower the car, and huge amounts of grip.
Old 06-11-2008, 06:43 AM   #5
Car: 07 SWP STI
Fav Mod: I-SPEED/Bride ZetaIII/Tein Flex
Teh Clap, your fantastical!!!
funSTi is offline   Reply With Quote
Old 06-11-2008, 02:10 PM   #6
Wheel33tist Whore
Ahh, thanks.
bet this is the only place where that sentence makes sense....
Old 06-11-2008, 02:23 PM   #7
Send a message via MSN to RFFG
I never make a tire fitment thread before t3h clap...
i need to whore more, lawl
RFFG is offline   Reply With Quote
Old 06-12-2008, 07:34 AM   #8
Fav Mod: shift knob
275 millimeters? Wow! Ok thnx
Old 06-12-2008, 07:36 AM   #9
Fav Mod: shift knob
Ok thnx for the 411 I'll check it out.
Old 06-12-2008, 08:33 AM   #10
Wheel33tist Whore
it is possible to fit it on the 8" wheel but it isn't possible to fit it on the stock wheels without spacers.
I've got a set of 275/40/17s on my Stock BBS's right now and trust me they need a 5mm spacer to clear the struts/trailing arms.
even then they rub slightly on the trailing arm
for a stock wheel it'd say 245 is a great size to stick with.
Old 06-12-2008, 08:47 AM   #11
Fav Mod: shift knob
What brand of spacers do you run my friend?
Old 06-12-2008, 08:59 AM   #12
Wheel33tist Whore
Currently I have 2 sets of CCW spacers
one set of 15mm hubcentric (wheel and hub)
one set of 5mm hubcentric (hub only)
since i'm on coilovers i needed more than 5mm clearance to clear the struts so i got 15mm spacers and ARP longer wheel studs.
now I use the 5mm spacer in the front to fit my 17x10s with the same 275/40/17
more info on my setup here.
17×10s and 275s, the BSP Minimum! T3h_clap’s BSP STi » t3h_Clap’s Wheel33tist Blog
for stock studs i would recommend not buying spacers at all.
there isn't enough engagement to do it comfortably.
