Old 06-03-2008, 07:43 AM   #1
Car: 05cgmsti
Default rota torque
i'm thinking about getting rota torques, i've seen some where they look concave and thats exactly how i want them to look. does anybody know if its due to the width or the offset?
nf_st,' is offline   Reply With Quote
Old 06-03-2008, 09:55 AM   #2
Car: '05 CGM STi
Fav Mod: Cracked VF39
Default Re: rota torque
Mmm, perhaps this question would best be answered in the wheels and tires section?
deegee is offline   Reply With Quote
Old 06-03-2008, 02:49 PM   #3
Car: PSM '05 STi
Fav Mod: S203 BBS RE's
^^^Haha, ever the gentleman...lol.
OP: You need to PM Suby_dude/Wheeldude here or on Nasioc.
UltimateLurker is offline   Reply With Quote
Old 06-03-2008, 07:07 PM   #4
Car: 02 Subaru WRX
Fav Mod: Catless up/dp Cobb V1 AP STG2
Wheel dude is the guy you want to ask...He actually has a direct screen name that you could talk to him on over AIM instant messanger if you have that, his screen name is Wheeldudesales add him to ur buddy list and IM him, hes a actual person you talk to and answers any questions you would have about Rotas.
gprsti is offline   Reply With Quote
Old 06-04-2008, 03:20 AM   #5
Car: 05 STi - Black
Fav Mod: No Lien
you will NOT get the concave look until you start getting into the agressive offsets - meaning you'll need to do some fender pulling, and running an aggressive alignment.
Old 06-04-2008, 10:51 AM   #6
Wheel33tist Whore
and they don't clear brembos.
T3h_Clap is online now   Reply With Quote
Old 06-04-2008, 01:07 PM   #7
Car: Subaru, Subaru stuff
Fav Mod: Parts Whore
The Torque wheels with concave are all Torque models with a 9"+ width. We often refer to this wheel as the Torque R. We have a 17x9 Torque R and a 18x9.5 Torque R.
We offer the 18x9.5 model in a higher +35 offset for 5x100 however all of our 5x114.3 models are a lower +20 offset which I would not recommend for the 05+ STi.
We also have a 17x9 model available which comes in 5x114.3 +30. This wheel does clear Brembo's and does not require spacers. This is still a very aggressive fit and will require some fender modifications and negative camber if you want to run a properly sized tire.
Here are some shots of the 17x9 model in Full Royal Sports Bronze, again no spacers required and they do clear Brembo's
If you have any other questions let me know!
-Dan
SubyDude.com is offline   Reply With Quote
Old 06-04-2008, 01:11 PM   #8
Also if you were only looking for a 18" wheel with concave I would look at the new Rota G-Force which is available in 5x114.3 +30 and for 04 sti guys 5x100 +35.
In 5x114.3 this wheel is available in Gold, Flat Black Red Lip, and Gun Metallic
Gold
Flat Black Red Lip
Gun Metallic
-Dan
Old 06-04-2008, 01:30 PM   #9
Wheel33tist Whore
the 18x9.5 +35mm 5x100 does not clear brembos though correct?
I see you mention it as being available yet no mention of brembo clearance.
Old 06-04-2008, 01:44 PM   #10
Car: 05cgmsti
thanks for all the answers subydude. Does the concave look only apply to 9"+ width on the g forces also?
Old 06-04-2008, 01:58 PM   #11
Correct, the 18x9.5 5x100 +35 requires a 5mm spacer in front to clear STi Brembo calipers.
thanks for all the answer subydude. Does the concave look only apply to 9"+ width on the g forces also?
No problem! The G-Force wheel is available in 17" and 18" for the STi. The sizes are 17x8, 18x8.5, and 18x9. The 17x8 +48 does not have concave, the 18x8.5 +48 has little concave, and the 18x9 +30-+35 has a lot of concave
Here's how the 18x8.5 G-Force looks on a customers car
-Dan
Old 06-05-2008, 05:03 PM   #12
Car: 05 sti
Fav Mod: stereo
in order to run the 18by 9 ,do u need to roll the fenders with properly sized tires? can u cut the fender liner or the fender itself? what was modified to the customers car above to fit such a wide rim and tire in the fender?
rallyracersti is offline   Reply With Quote
Old 06-05-2008, 07:20 PM   #13
The 18x9 Gold G-Force's on the white STi had really small 225/40/18 Falken FK452's. He wanted to have his car extremely low and so to do this he had to run a narrow tire and a good amount of negative camber in the rear. His car is a 04 STi and he completely rolled the front/rear fenders.
If you don't want to do a lot of fender modification or negative camber I would go with a 235/40/18 tire for the 05+ STi. If you are okay with pulling your rear fenders a bit (relatively easy to do and allows for a much wider tire) then I would go with a 255/35/18 tire as this will fit the 9" wide wheel very well and match your stock rolling diameter.
Here's an image a customer of ours took, he is running 245/40/18 tires.
-Dan
