Old 05-15-2008, 11:20 PM   #1
Car: 06 STi/00 L
Fav Mod: trunk monkey
Default 3mm spacers do anything?
so i think i want my stance to be a bit more aggressive, i've got 18x8.5 e48's on it now would a 3mm spacer even make a difference? something noticable? i'm sitting here looking at 3mm on a ruler i hear 5mm is pushing it and i dont really wanna push it if ya know what i mean, just looking for a more aggressive stance
thanks
kessler89 is offline   Reply With Quote
Old 05-16-2008, 03:37 AM   #2
Car: 05 STi - Black
Fav Mod: No Lien
Default Re: 3mm spacers do anything?
not sure how much of a visual difference it will make, however 3mm is the most you should go with stock studs.
Old 05-16-2008, 05:00 AM   #3
Fav Mod: Motor Mounts
They will put each wheel out 3mm...
I wouldnt use 3mm spacers for street use though. If you do I would certanly check your wheel lug tq from time to time.
Old 05-16-2008, 05:02 AM   #4
is, in fact, a lolcat.
Fav Mod: banhammer
Spacers are really for gaining needed clearance. If you're not rubbing on the strut side or trying to clear brakes, you don't need them. EDIT: I guess what I'm saying is, if you don't need them, I wouldn't run them.
If you MUST run them, anything more than 3mm will most likely require extended studs. To find out if you're going to rub once you put the spacer on, measure inner fender-to-tire distance. I've ordered some 3mm universals to test. If they give me the clearance I need, I'm likely going to order some custom hubcentric ones.
And no, I doubt you'll be able to see 3mm of difference.
Old 05-16-2008, 05:47 AM   #5
I would agree. I have a lot of experence with spacers but only because I use them to gain clearance for track days...I certanly dont use them to get any sort of look. You would be better off getting the right offset rims if you are trying for a certain look.
Also...you can use 5mm spacers but you are pushing your luck. I used them when I had stock lugs and I was somewhat paranoid about it.
Old 05-16-2008, 05:48 AM   #6
Fav Mod: banhammer
I'm hoping that a set of hubcentric (to the car and the wheel) 3mm spacers will solve my ever-so-slight rubbing issue and allow me to avoid the extended stud nightmare.
Old 05-16-2008, 06:10 AM   #7
Do spacers come that small hubcentric? You know the extended studs are not that bad to install. The front is cake, the rear is a PITA but do-able. I could probably do each side tire on to tire off in 1-2hours.
Old 05-16-2008, 06:11 AM   #8
Fav Mod: CarComfortDesign@Gmail.com
can someone steer me in the direction to get 3mm spacers for my 06 STi?
JZeezSTi is offline   Reply With Quote
Old 05-16-2008, 06:12 AM   #9
Fav Mod: banhammer
They'll be custom made.
