View Poll Results: Should all Subarus including the STi come with a full-sized spare standard?
Yes! Donut spares suck! 25 78.13%
Yes! I want to change the spare and go! 7 21.88%
Voters: 32. You may not vote on this poll
Old 04-29-2008, 04:55 PM   #16
Fav Mod: Motor Mounts
Default Re: Full-sized Spare
How the hell do you get a million posts?
Old 04-29-2008, 04:57 PM   #17
Fav Mod: Ring-Shaped Reinforcement Frame
I'm confused. Is a full size spare actually full size? I mean is it full diameter and full width? Or is it just full diameter? I thought the STi spare was full size. Am I wrong?
Edit: just noticed both choices in the poll are "yes" lol.
Old 04-29-2008, 04:58 PM   #18
WTF H4XXXX!!!!111
Old 04-29-2008, 05:01 PM   #19
Car: '07 STI Limited
Fav Mod: crashing
Send a message via AIM to stiltd683
I dont even have a spare...just a can of fix-o-flat.
I had a blow out 200+ miles away from my home that completely ripped the tire in two pieces. fix a flat doesn't cut that kind of ****. I sat in a random tire store for 7 hours waiting for a REO70 to come in. It was right after I bought my car, So I had few enough miles just to but one, and I couldn't afford to get 4 new tires in what they had in the store, I agree with snowbordr
stiltd683 is offline   Reply With Quote
Old 04-29-2008, 05:03 PM   #20
I rarely take my car out of town. I have another DD car. Also if I do take it OOT I put the spare back in FWIW.
Old 04-29-2008, 05:23 PM   #21
Drive True
When I say full-sized spare, it's simply an extra rim of the same size and tire, so all you have to do is put it on and go. You don't have to drive gingerly for as few miles as possible, you use the spare, then when you get home, you replace/repair the damaged one and stick it in the trunk as your new spare.
SnowbordrWRX is offline   Reply With Quote
Old 04-29-2008, 05:52 PM   #22
Reasonable
Fav Mod: correct grammar
Too much porn.
Originally Posted by USNSTI View Post
WTF H4XXXX!!!!111
He is a rocket scientist. Yes, I am serious.
Keep this thread on topic, please.
Old 04-29-2008, 06:45 PM   #23
LSE
Fav Mod: Defi Gauges
Originally Posted by SnowbordrWRX View Post
How much added weight? I lost 27 lbs from when I first got the car, so with a full-size spare the whole setup is still lighter.
I think the RE070 is 27lbs. plus rim, man you better get on the subway diet
Old 04-29-2008, 06:52 PM   #24
Car: 2006 Subaru WRX STI
Fav Mod: Maddad DP and P&L Catback, stage 2!!!
Send a message via AIM to haroman311
as long as its the same diameter, then you are good to go.
haroman311 is offline   Reply With Quote
Old 04-29-2008, 07:34 PM   #25
I would rather have the lighter spare. I don't consider it a donut spare if it is the same diameter.
Old 04-29-2008, 09:34 PM   #26
Drive True
uh, you have to subtract the weight of the donut spare though...which isn't it steel? I'm about 27 lbs lighter than I was a year ago so me + car + full sized spare < me a year ago + car + donut spare
Old 04-29-2008, 09:35 PM   #27
Drive True
but it's not though
Old 04-29-2008, 09:37 PM   #28
Drive True
Originally Posted by boondocksaint View Post
Too much porn.
was a rocket scientist. was let go, now have new job...to pay for my full-sized spare. I've lost the spare tire around my midsection so now I can have a heavier car, I guess.
Old 04-30-2008, 12:29 PM   #29
Car: 04 WRB STi
Fav Mod: JDM STi Recaros
Here's the point: you're not going to get it unless you do it yourself. Car companies are not going to spend the money and add the weight for a full sized. It obviously means that much to you so why don't you just buy a spare wheel and tire and find a place for it, according to thump a full sized BBS will fit in there. If its not working for you, make it work!
yakmasterjack is offline   Reply With Quote
Old 04-30-2008, 03:15 PM   #30
Drive True
I disagree. If enough people want it, car companies will change. I already did by a spare rim and tire, but it should've been there in the first place...or at least an option.
