Old 04-25-2008, 09:44 AM   #1
Car: 06 STI Steel Gray
Fav Mod: SS Stage 2+ Tune
Default Replacement Tires 06 STI
Hello All,
I am thinking of getting the Nitto INVO 225/45ZR-17 91W BLK to replace my stock Bridgestone 070s with 27K miles. Any thoughts or anyone know a good local place? Online the price is $115/ea. I would like to keep similar performance / handling. From what I have read the INVO would be similar to the 070s. However if it were a bit less harsh that would be ok since it is my DD. If going to the track I would use other wheels and "R" tires.
warfare is offline   Reply With Quote
Old 04-25-2008, 09:59 AM   #2
Reasonable
Fav Mod: correct grammar
Default Re: Replacement Tires 06 STI
Many many many people have asked about good replacement tires. I'm not a fan of Nitto, as I've vicariously had bad experiences with them through friends. If you want budget performance tires, Falken Azenis RT615s are popular. I like mine quite a lot.
Almost any tire will be less harsh than RE070s, because almost any tire will have a softer sidewall, some more than others. Do a little searching. You'll find what's popular and why.
Old 04-25-2008, 10:07 AM   #3
Car: 07 OBP STi
Fav Mod: patience
look at BS RE01R - heard nothing but great things about them on both the street and track.
monk is offline   Reply With Quote
Old 04-25-2008, 11:00 AM   #4
From reading here and others it seems the Nitto INVO is on the softer side due to the sidewall. I have had Falken Anzenis Sports in the past on my 2K A4 1.8T Quattro and enjoyed them. It seems the next generation of that is the Azenis RT-615
Old 04-25-2008, 11:07 AM   #5
Reasonable
For what its worth, there are a number of good options, although some of them don't offer certain sizes. If you're going to put these on stock wheels, I'd say get a 235/45 or a 245/45 (stock suspension). Any wider and you'll have a significant bubble from the sidewall. 235/45-17 is the JDM stock tire size.
