Old 04-21-2008, 06:18 AM   #1
Car: 04 Subaru Impreza WR
Fav Mod: ARC intakes
Default 08 STi 18 inch rim, do they fit 04 STi?
Will these fit on 04 sti? Help... I really like them... in GOLD ofcourse...
thanks
whitewhale2070 is offline   Reply With Quote
Old 04-21-2008, 06:20 AM   #2
Car: 04.5 STi- PSM
Fav Mod: learning how to drive
Default Re: 08 STi 18 inch rim, do they fit 04 STi?
nope
those are 5 x 114.3
04 sti is 5x100
misterwaterfallin is offline   Reply With Quote
Old 04-21-2008, 06:23 AM   #3
Fav Mod: Access Port V2
what about an 05?
St-ill is offline   Reply With Quote
Old 04-21-2008, 06:50 AM   #4
Car: 07 OBP STI
Fav Mod: AutoSpeed Catback
yes they will fit 05 to 07s no prob
PuccasBad_STI is offline   Reply With Quote
Old 04-21-2008, 07:00 AM   #5
Fav Mod: Motor Mounts
Yep...the 08 boat anchor's wont fit an 04.
Old 04-21-2008, 07:28 AM   #6
Car: '04.5 STi
Fav Mod: ZZYZX
The '08's will fit when you fix the '04's wheel bearing problem.
Well, they'll bolt up anyway, may not clear the suspension.
Old 04-22-2008, 01:50 AM   #7
ohhhh... wheel bearing? explain more please... how about the similar oem wheel for 350z?
Old 04-22-2008, 06:31 AM   #8
Car: 04 sti
Fav Mod: enginuity tuned
the 04 sti is the only sti with the 'weak' 5x100 hub, while 05+ get the 5x114.3 which is stronger and more robust.
and no, the offset on the 350z wheel is probably way off for our cars.
Old 04-22-2008, 09:04 AM   #9
Wheel33tist Whore
more importantly the bolt pattern on the 350z is 5x114.3
Old 04-22-2008, 02:07 PM   #10
Are those lighter than the 08 BBS rims?
Old 04-22-2008, 06:57 PM   #11
Send a message via AIM to midnit
Definitely not. The stockers are approx 28 lbs from what I've been told, whereas the 08 BBS rims weigh in at 19.6 lbs.
Ref:
Rim Weight??
midnit is offline   Reply With Quote
Old 04-24-2008, 11:59 PM   #12
Car: 06 Aspen White STI
Fav Mod: Defi's
28lbs sounds like a lot. what do the 17X8 BBS (05-07 years) weight?
Iguana is offline   Reply With Quote
Old 04-25-2008, 03:22 AM   #13
Car: 05 STi - Black
Fav Mod: No Lien
19lbs
05_GD7 is online now   Reply With Quote
Old 04-25-2008, 05:26 AM   #14
Wheel33tist Whore
i took off an 08 wheel last night and that ****er is heavy.
heavier than my 17x10 CCWs w/ 275/40 V710s
Old 04-25-2008, 10:05 AM   #15
Car: 08 Gray STi
Anyone seen a good deal on 1 or 2 of the OEM basic rims?
