Old 04-08-2008, 11:53 AM   #1
Car: 06 Subaru WRX STi
Fav Mod: JIC Spartan Type II catback
Default 5Zigen PRORACER ZR+520
Anyone running these wheels? I'd like to see pictures of them on an STi before I buy a set. Also, I'm debating between
18x8.5 +47
or
17x9 +37
I'd really like to run the wider 17x9's but I'm not sure if those will fit.
Any input at all is welcome!
EveeSTi is offline   Reply With Quote
Old 04-08-2008, 12:29 PM   #2
Car: 06' STi, de-pinked
Fav Mod: RCE Tarmac II, +27 Enkei RPo1
Default Re: 5Zigen PRORACER ZR+520
18x8.5 +47 will be no issues at all.
I've run the same wheel size, with a +44 and no rubbing (245/40/18 RT615 tire).
A 17x9 +37 should also fit without issue, as long as you have your camber set up properly, and you're not running an extremely wide tire, like a 265 or something.
18" +35 is when you start running into problems rubbing on the fenders, and around 9.5" is when you start to run out of room with the suspension on the inside.
hypa is offline   Reply With Quote
Old 04-09-2008, 06:49 AM   #3
Wheel33tist Whore
the 18x8.5 +47mm will work.
the 9" wont work on stock suspension unless you do some modifications. And I haven't seen any evidence that the 9" +37mm clears brembos.
