Old 04-06-2008, 10:29 AM   #1
Fav Mod: 255's ftmfw
Send a message via AIM to sticop
Default spacers
ive done a bit of searching on here and nasioc about wheel spacers. I found some sweet ssr gt2's 18x8 but theyre +51 offset
would i be okay running these with a 3mm spacer to get them to +48 offset so they would clear the brakes and allow me to run 245's or 255's?
sticop is offline   Reply With Quote
Old 04-07-2008, 01:24 PM   #2
Wheel33tist Whore
Default Re: spacers
they make them in a size that clears.
Old 04-07-2008, 02:03 PM   #3
Fav Mod: Motor Mounts
Default Re: spacers
You could certanly run 3mm spacers. I would try for the right wheel offset before I started monkeying around with spacers. I only use them for track use...I wouldnt want to run spacers on the street.
Old 04-07-2008, 03:30 PM   #4
Fav Mod: jailbreak
Default Re: spacers
you can run 3-5mm fine. the main thing is to be sure you have proper thread engagement and the spacers are hubcentric. 5mm is on the edge IMO and depends on your wheel lug seats and lug nuts.
Old 04-07-2008, 05:12 PM   #5
Default Re: spacers
roger that guys, ill just keep searching. thanks for your input
Old 04-07-2008, 06:28 PM   #6
Fav Mod: jailbreak
Default Re: spacers
good luck! finding that perfect set of wheels sux
Old 04-07-2008, 06:30 PM   #7
Wheel33tist Whore
Default Re: spacers
only if you have an 04....
oh wait.
sorry guys...
Old 04-07-2008, 06:32 PM   #8
Fav Mod: jailbreak
Default Re: spacers
hey, it only took me over 4 years
