Old 03-29-2008, 03:28 AM   #1
Car: 06 white STI
Fav Mod: Borla catback
Default Painting wheels...which primer?
I am using Duplicolor high performance paint but I couldn't find high temp primer. I ended up buying Duplicolor sandable primer but wanted to check if I should use something else. Is primer primer?
cawayne is offline   Reply With Quote
Old 03-29-2008, 04:19 PM   #2
Young and restless
Car: 2005 Aspen White STI
Fav Mod: Torque
Send a message via AIM to MikeO Send a message via MSN to MikeO
Default Re: Painting wheels...which primer?
Primer is primer. Most people don't even use a primer when spray canning their wheels. I just got my paint from duplicolor in the mail yesterday and i won't be doing a primer either.
It can't hurt to prime it with what you've got though! I would recommend getting something abrasive to add some texture on the wheels before applying the paint and primer so it all sticks better.
Good luck!
MikeO is offline   Reply With Quote
Old 03-29-2008, 06:28 PM   #3
Car: 06 white STI
Thanks, makes me feel better. Got two coats of primer on today and satin black goes on tomorrow. Apparently all coats of paint need to go on within an hour. Looking forward to getting the wheels back on the car, pains me to see it up in the air on the driveway.
Old 03-30-2008, 07:44 AM   #4
Car: Blue 07 WRX STI
Fav Mod: Soap
As said above, primer is primer.
The only time you should use primer first is if the bare metal under the existing clear coat and paint is exposed. It doesn't hurt anything, though, if you use it over your existing paint/clear coat.
Like said above, scuff up the surface (really the clearcoat) before applying the paint to help it last.
STI Sibb is offline   Reply With Quote
Old 03-30-2008, 07:52 AM   #5
The Stig II
Fav Mod: EFI Logics tune
I have to say the BEST primer I have ever used...one that actually sticks and will not peel if applied properly is Primacon under water primer. It can be had from any marine supply store.
Joe
jnprn2003 is offline   Reply With Quote
Old 04-03-2008, 06:52 PM   #6
Car: 06 white STI
Well I did it, two coats of primer, three coats of paint, two coats of clear coat. Got to say my gold Brembos look great with the contrast. Black and gold looks much better in my opinion than silver and gold. I was going to paint the Brembos red but won't now.
Old 04-03-2008, 10:22 PM   #7
Car: 04.5 STi- PSM
Fav Mod: learning how to drive
i picked up some self etching primer to coat my rims with...i still have to fix that curbing.damnit
misterwaterfallin is offline   Reply With Quote
