Old 03-22-2008, 04:48 PM   #1
platinum member
Car: 06 sti #60 BSP
Fav Mod: 295/A6 hoosiers
Default installing wheel studs
replaced wheel studs today ,had some friends look at car. they came up with a easy way to install the studs. take a extra lug nut i used a extra gorilla one. drill a hole in the end take a hardend bolt install it in threw the cap. then screw it on to a slide hammer,pull youre stud threw screw the lug tool on the stud whack it a few times works great. hope this helps jv
jv01 is offline   Reply With Quote
Old 03-23-2008, 11:49 AM   #2
Car: 06 Subaru WRX STi
Fav Mod: leaving it stock
Default Re: installing wheel studs
why not just use one of these...its cheaper than having to buy a slide hammer.
houdni is offline   Reply With Quote
Old 03-23-2008, 12:30 PM   #3
platinum member
Car: 06 sti #60 BSP
how do you use that tool
Old 03-23-2008, 04:29 PM   #4
put in the wheel stud...use the lug nut to draw in the stud...it has a bearing within the tool...
Old 03-23-2008, 04:48 PM   #5
platinum member
Car: 06 sti #60 BSP
i tried to do that with washers and the lug it seems to deform the threads . useing the slide hammer the lug is threaded all the way on it has more surface area seemed to protect the whole lug . just my .2 cents
Old 03-24-2008, 10:17 AM   #6
Trader Rating: (50)
I've always pulled them through with some washers and a lug nut and never had any problems.
Old 03-25-2008, 01:45 PM   #7
Fav Mod: jdm fogs
Send a message via AIM to krazy
I always stack open ended lug nuts, and ditch the idea of using a washer. Also throw the stud in the deep freezer a couple of hours before using. it will go in like butter.
krazy is offline   Reply With Quote
Old 03-25-2008, 01:57 PM   #8
Wheel33tist Whore
also depends on the quality of the wheel stud.
lower quality studs will deform.
T3h_Clap is online now   Reply With Quote
Old 03-25-2008, 02:43 PM   #9
Non-Reformed Meth Addict
Car: '06 WRB
This works wonders.
Old 03-25-2008, 04:45 PM   #10
Fav Mod: in transit
what brand of wheel studs are recommended? if i go for the 18x9.5 offset 37? thanks
impressive is offline   Reply With Quote
Old 03-25-2008, 05:10 PM   #11
Black Dragon STI
Car: 07 OBP STi 03WRB WRX
Fav Mod: My whole suspension
The stock studs should be fine unless you are going to use spacers (though with a +37 offset, why would you?). Usually people install longer studs so they can space out the tires and increase track width.
Old 03-26-2008, 12:49 PM   #12
Fav Mod: Motor Mounts
Yep...I just stacked 6 hardened washers and pulled it through. I like the freezer idea too...
Old 03-26-2008, 12:50 PM   #13
Most people run ARP wheel studs. That said I stripped one of them out pulling it through...
Old 03-27-2008, 07:00 PM   #14
Fav Mod: jailbreak
i did the washer thing with eibach studs and it worked perfect
Old 03-27-2008, 07:18 PM   #15
If I just want 10mm spacers, what extended studs you recommend? Also, will I able to use my existing lug nuts?
yohan7 is offline   Reply With Quote
