Old 03-04-2008, 07:55 AM   #1
Car: 2007 STI Limited
Fav Mod: Stage 2
Send a message via AIM to coop1103
Default Gram Lights 57 Maximums-Teh Clap???
18x8.5 with 235/40/18's
45mm offset
Will these fit my 07 Limited no problem?
And would you take these over O.Z Ultralegerra's?
coop1103 is offline   Reply With Quote
Old 03-04-2008, 08:39 AM   #2
Is Scared Of Kevin...
Default Re: Gram Lights 57 Maximums-Teh Clap???
yep.....pretty sure thier perfect!
MKTURBO is offline   Reply With Quote
Old 03-04-2008, 08:40 AM   #3
Reasonable
Fav Mod: correct grammar
45mm offset
The Clap himself has run these on the track:
18x8.5 +45mm Gram Light 57 Maximums with 265/35 A048s
If you're on stock suspension, you should be fine depending on how much tire you want to tuck. 265s may require fender mods/camber.
Old 03-04-2008, 09:27 AM   #4
Fav Mod: Stage 2
Tires are 235/40/18 and they are all seasons which i am not happy about but I cannot pass up the deal. I wont have to roll any fenders or any other modifications right?
Old 03-04-2008, 09:31 AM   #5
Reasonable
I'm 99% sure they will not require mods, but you should NOT take my word for it.
Old 03-04-2008, 09:37 AM   #6
Car: 04 sti
Fav Mod: enginuity tuned
45mm offset
yes, the should with those specs.
and definitely yes over the ultraleggeras.
Gram Lights 57F = 18x8.5_ET45__(18.5 lbs)... (Luke@Tirerack)
Old 03-04-2008, 09:49 AM   #7
Wheel33tist Whore
yup, those will fit nicely.
it's the same wheel I have.
I've got 265/35/18 Hankook RS2 Z212s on them right now for the street.
never had A048s on them as boony remembers, wish I did.
Old 03-04-2008, 10:08 AM   #8
Reasonable
Sorry. I got it from this post:
17X9+ on 05 STI with what Offsets???? UPDATES -- T3h_Clap FTW!
Does this wheel/tire combo require fender mods for the OP's application?
Old 03-04-2008, 10:11 AM   #9
Wheel33tist Whore
damn, i've had these gramLights forever...
anyway, the OP's application will have zero issues on 90% of suspension setups.
especially if he stays with a 235/40/18 tire.
Old 03-04-2008, 10:23 AM   #10
Fav Mod: Stage 2
Yea they come with a 235/40/18 tire. So I am good to go!!?????If i decide to do suspension upgrades in the future will i have any problems?
Old 03-04-2008, 10:28 AM   #11
Wheel33tist Whore
nope, you'll be good to go, as long as you keep a 235/40/18 tire on there.
once you finalize your suspension it may be possible to step to a wider tire.
Old 03-04-2008, 10:33 AM   #12
Fav Mod: Stage 2
Final question: Will the gun blue look good on my UGM Limited???? I cannot find any pics after a search.
Old 03-04-2008, 10:35 AM   #13
Wheel33tist Whore
i think it would.
Gunmetal looks good on almost all colors.
the gunblue has a very small hint of blue in certain lights, not much though.
Old 03-04-2008, 10:49 AM   #14
Fav Mod: Stage 2
That is good, because I think the UGM shows some hint of blue in certain lights as well. Thanks for all of your help. Responses were great and quick!!! Hopefully they are still available and I can complete the sale tonite!
