| Junior STI Driver Car: 04 Subaru WRX STi Fav Mod: Coming Soon Location: perry, oh Posts: 57
IWSTI Addict since: Sep 2007 Trader Rating: (0) | I just got 4 new tired mounted and balanced and will be going to firestone for an allignment tomorrow. I have a 04 sti with rce yellow springs and thats it for now. for aggressive street/some track use what specs should I give them to set my car up to. Thanks for any help in advance Nick This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #3 |
| Wheel33tist Whore
Car: Aspen White GDF-D Fav Mod: Pastelito Racing / SFSOC Location: 0R!4ND0 Posts: 21,508
IWSTI Addict since: Dec 2004 Trader Rating: (7) | How To: Setup your Street alignment the right way. » t3h_Clap’s Wheel33tist Blog here ya go, a little blurb on what needs to be done. exactly what 05_GD7 said but with a link you can find easier in the future. |
| | #4 |
| Poor Speed Racer Car: 96 328 Fav Mod: Tightening the nut behind the wheel! Location: Northern VA Posts: 8,446
IWSTI Addict since: Mar 2005 Trader Rating: (8) | Max out the front camber, which will be around -1* if you are lucky. The rear camber is non adjustable so you cannot change that and get 0 toe all the way around. also if you just got tires mounted and balanced you dont need an alignment. However, if you just put the springs on you do. |
| | #5 | |
IWSTI Addict since: Sep 2007 Trader Rating: (0) | Quote:
| | #6 |
IWSTI Addict since: Sep 2007 Trader Rating: (0) | and when you say max out the camber with the stock bolts you mean get the most camber posible right? further away from 0* |
| | #7 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | as negative as possible. the alignment guy may fight you, but he should be able to get at least -.7 in the front. |
| | #9 |
| Silver Member
Car: 2004 WRB STi Location: Atlanta,GA Posts: 2,086
IWSTI Addict since: Aug 2006 Trader Rating: (14) | there is not a specific value for rear camber, is "Adjust Toe eccentric to be Zero left and right" going to correclate and setup a camber with respect to front camber? This ad is not endorsed by this member. Please register or login to hide this ad. |
