Old 06-26-2008, 03:49 PM   #31
Car: Blue 2006 STI
IWSTI Addict since: Apr 2008
Default Re: Installed ARP Extended Studs Through ABS Sensor Port
well polyol and I just did this to my car - 06 STI - and everything is working great. Thanks poly
sti4rs is offline   Reply With Quote
Old 07-03-2008, 03:21 PM   #32
Car: Car Builder
Fav Mod: Boost
IWSTI Addict since: Feb 2006
Send a message via AIM to token-negro Send a message via MSN to token-negro
At my friends house with an 06 and were trying to install the fronts with Zero luck? did u have to take the axles out of the front?
token-negro is offline   Reply With Quote
Old 07-07-2008, 10:16 AM   #33
Car: Blue 2006 STI
There are 4 bolts that hold the hub assembly together on each side. I loosened those up about 1 inch maybe 1.5 inches. That gives you enough room to slide the new wheel studs in.
Old 07-07-2008, 12:18 PM   #34
Car: Car Builder
Fav Mod: Boost
yeah did that we got them in.
Old 07-07-2008, 12:21 PM   #35
Halliburton Mercenary
Car: AW GDF-D
Fav Mod: Q-Rack
IWSTI Addict since: Oct 2005
Trader Rating: (12)
pinch those axle nuts!
Old 07-07-2008, 12:22 PM   #36
Car: Car Builder
Fav Mod: Boost
ohh we wernt done, give me more credit then that
Old 07-07-2008, 12:32 PM   #37
Car: Blue 2006 STI
looks good.
Old 07-07-2008, 01:03 PM   #38
Car: 06 STI UGM
Fav Mod: (o)(o)
IWSTI Addict since: Jul 2006
I'm going to be doing my front and rear studs soon as well! I purchased the NISMO 50mm studs since I stripped one of the stock studs the other day
Is the "how to" on scoobymods on the rear of an 04 going to be the same as my 06?
Is there a "how to" for the fronts that I can look at?
Thanks,
JAYMAC10 is offline   Reply With Quote
Old 07-07-2008, 02:17 PM   #39
Car: Car Builder
Fav Mod: Boost
Thanks,
Pull the front axles pull apart the hub, IF u cant get them in from the back some how. ARP's were just to long. U might have better luck. As for the rear should be the same oger out the ABS sensor hole if u cant get them in otherwise. BTW take a picture of the parking brake setup before u rip it apart.
Old 07-30-2008, 10:21 AM   #40
Car: Silver 06 WRX/STI
IWSTI Addict since: Apr 2006
I have done the same thing. I switched out the front and the rear. The fronts were easy but the rears were PITA. I had to grind down the ABS sensor hole to fit the extended studs. How do you like the ARP studs? I stripped the studs so I need new ones.
kitganzon is offline   Reply With Quote
