Old 02-21-2008, 08:26 AM   #16
Fav Mod: Motor Mounts
IWSTI Addict since: Oct 2004
Default Re: Installed ARP Extended Studs Through ABS Sensor Port
Originally Posted by sciolist View Post
You do know that you can just knock off the side of the studs' flanges, right?
Yes, I actually did make one of the studs look like a D but that would not allow it to pass through. Not even close really. I dont understand how the people who made it work given the geometry that I had to overcome...unless the ABS hold is different in the 05+'s.
Old 02-21-2008, 08:31 AM   #17
Fav Mod: jailbreak
IWSTI Addict since: Aug 2003
i'd rather grind the hole than the stud anyway.
Old 02-21-2008, 08:32 AM   #18
Spiteful Old Codger
IWSTI Addict since: Jul 2003
Originally Posted by T3h_Clap View Post
or install them on a new set of 5x114.3 hubs...
No isht. Poly does not listen to this kind of reason, though. He prefers to go around his elbow to get to his thumb.
Assume a subject project that consumes $1K and 2 days. It's cheaper to do that in 99 ten-dollar increments over two decades, don't you know?
Old 02-21-2008, 08:36 AM   #19
No no no...come now. Why would I replace my hubs when they are still going strong...maybe I have some factory freak setup becasue I have 65K on my STi with more track days than I can remember. When they are blown, I will replace them with upgraded hubs. Most certanly 5x114
Old 02-21-2008, 08:36 AM   #20
Spiteful Old Codger
I got one to work that way, just jacking around in the shop when we did my hubs. Maybe your ports are different.
Anyway, kudos for thinking "outside the bun" and cutting your way through the back door. I'm sure there's a metaphor in here somewhere that could find its way onto the side of a guy's car in magnetic, if he happened to show up at certain events...
Old 02-21-2008, 08:41 AM   #21
Spiteful Old Codger
I'm going to go out on a limb here and guess that just living in Eugene causes any sort of orifice to dilate. So, seems like you would have an advantage, if anything.
Old 02-21-2008, 10:09 AM   #22
Just what are you trying to say... Unfortunatly the spacial dilation you refer to did not help me out with the install since I technically live in the county so...there...
Old 02-21-2008, 10:30 AM   #23
Spiteful Old Codger
^Ah, Plasticus hedges his bet. Likely a wise precaution on the part of the family man.
Old 02-22-2008, 08:02 AM   #24
Fav Mod: jailbreak
everything cool?
Old 02-22-2008, 12:26 PM   #25
Ok guys got everything on and took it for a drive...no abs light or any problems. Sensors lined up with the spline just fine and it does not wiggle around or anything. Everything is cool so far . If I run into any problems I will post it up.
All said...do this at your own risk. I take no responsibility for you messing up your ride. If anyone has any specific questions about the job...let me know.
Now I get to deal with the fronts...which should be much more pleasant.
Old 02-22-2008, 02:27 PM   #26
Fav Mod: jailbreak
if you gto some pics that'd be awesome. i could figure it out from there, but a diy would be helpful for alot of peeps
Old 02-22-2008, 02:47 PM   #27
Ill see what I can do. I have it all back together now but I might be able to get some pics.
Old 02-22-2008, 03:16 PM   #28
Follow this guide for the most part. Replace rear wheel stud on WRX/STi - ScoobyMods I ended up taking the parking brake assembly off...buuuut you might be able to do it without taking it apart. It certanly gives you more working room to remove it...and really its not that hard.
Next step will require a die grinder with a carbide tip. Dont even think about trying this with a Dremel. It would take forever, it takes long enough with a die grinder as it is.
In the picture below you can see the ABS sensor port. You have to get under your car and grind out/hone out the hole so that it is big enough to slide the head of the ARP wheel stud through. I ground out all around the hole till it was big enough. The part that I highlighted red is the area that you have to completly remove, you dont have to do that from under the car. You have to grind it down almost all the way to the dust plate. The cut away portion will look like a cresent moon when you are done.
When you take everything apart it will be clear what you have to do. It is much easier to have a buddy there to help too. Good luck.
Old 04-29-2008, 04:36 PM   #29
Car: 04 WRB STi
IWSTI Addict since: May 2006
Ok, this might seem dumb but I am trying to figure the options here. So, option one- you can grind down the abs sensor port into a half moon to get the stud to fit. Option two- you can remove dust plate? Option three- you can knock off the side of the stud flanges? Somebody correct this if it wrong. What is the easiest and safest option here?
jimbo15471 is offline   Reply With Quote
Old 04-29-2008, 05:06 PM   #30
I can say its been a few months and quite a few autox runs and everything is AOK. It takes me about an hour to do each side...well..now that is. So the method I used is quite quick and effective.
