Old 02-20-2008, 07:08 AM   #16
Fav Mod: jailbreak
Default Re: 17x9 +44 work kai fitment issue
sweet. did you buy more than one? should of got like 2 or 3,then you could have stacked them if 5mm isn't enough. (to check it,not roll around on)..but we all know the rim god will make sure 5mm is enough
Old 02-20-2008, 02:34 PM   #17
rofl, okay i got the spacer i don't have time to try it till friday or saturday so we'll see. cross your fingers
drifterATheart is offline   Reply With Quote
Old 02-20-2008, 06:26 PM   #18
Fav Mod: jailbreak
aaaaaaaaaahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh just do it!! you'll be the hero of alot of 04 guys it only takes like 5 minutes!!!!!!!! gaaaaaaaaaahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh i'm dyin!! rollercoaster day found out the wheels are on time for this month, i got a 360 today,and you got the spacers!
Old 02-21-2008, 09:32 AM   #19
Car: PSM on Gold Volks
Fav Mod: GDB HID projector
and those 03 owners with brembos ....lets just hope all the 18's came in
SPOOLN is offline   Reply With Quote
Old 02-21-2008, 09:53 AM   #20
Fav Mod: jailbreak
phht screw the 18's
<(wishes he didn't miss that gb)
Old 02-21-2008, 09:56 AM   #21
Wheel33tist Whore
to clear brembos you need the 18x9.5 +30mm.
if you had larger rotors you could probably get away with the +38mm.
Old 02-21-2008, 10:28 AM   #22
Fav Mod: jailbreak
yeah i know that for the cr kai's . the 18x9.5 +38 xt7's are supposed to fit right up though.(hmm who told me that? ) i'd be leanin towards those with a 255/35 to start then man up to a 265 later if these don;t work out.
Old 02-21-2008, 10:32 AM   #23
Wheel33tist Whore
the XT7's in an 18x9.5 +38mm clear as per work.
I do like those...nice subtle concave good offset, great width.
hmm yummy.
as for the 17x9 +44mm CR Kai's lets see spacers!!
Old 02-21-2008, 10:35 AM   #24
Fav Mod: jailbreak
for reals!! do work s0n! it only takes a minute to throw on a spacer and wheel! you don't need a lift
Old 02-21-2008, 10:39 AM   #25
check back tonight i'll test fit it
Old 02-21-2008, 10:49 AM   #26
Fav Mod: jailbreak
i love you. i might have to cyber you if the 5mm works
Old 02-21-2008, 06:32 PM   #27
Fav Mod: jailbreak
anything ?
Old 02-21-2008, 07:54 PM   #28
Car: 2006 WRX FPGREEN
Fav Mod: Race Gas
in for the big news, i'm so excited! he just IMed me on AIM about test fitting them with the spacers.
06hwrx is offline   Reply With Quote
Old 02-21-2008, 08:16 PM   #29
bad news, front wheels with a 5mm still hits the brakes. with a 10mm theres probably 2mm of space between the spoke and brake. i have some pictures below
wheel size
the 5mm spacer
two 5mm stacked together to get the 10mm
5mm bumping against the brake
10mm spacer barely making it
and for reference my work kai 17x8 +47
sorry guys guess no cyber for me
i'll probably post the wheels back up forsale, don't really want to run a 10mm spacer. if anyone wants to take them off my hand pm me and we can work something out
Old 02-22-2008, 06:08 AM   #30
Fav Mod: jailbreak
got no problem running a 10mm spacer up front here thanks alot for the info dude. sorry to see you sell them though! 10mm with longer studs is perfectly fine! so you could spin the wheel and everything no problem? looks like the same clearence as the 17x8's basically....
my plan now i guess is to sell one set of the 5mm i got and get a set of 10mm for the front. so :
+34f/+39 rear. should be a decent setup i think. debating on how safe i'll be with the stock studs in the rear on the 5mm spacer...
