Old 02-12-2008, 06:06 AM   #31
Wheel33tist Whore
Default Re: About to buy TRMotorsport MT1... installed.
you're on stock springs still right?
T3h_Clap is online now   Reply With Quote
Old 02-12-2008, 07:20 AM   #32
Fav Mod: Ohlins struts
Yep. Stock springs, Ohlins struts, RCE lowering camber plates, and Whiteline 24mm front and 24mm rear sway bars.
SWortham is offline   Reply With Quote
Old 02-12-2008, 08:46 AM   #33
Fav Mod: jailbreak
look pretty good. a little more drop would be cool. the rce springs should complament your setup nicely
munky69 is online now   Reply With Quote
Old 02-12-2008, 08:58 AM   #34
I used to have RCE yellow springs but decided to take them off since this is my daily driver 1st and track car 2nd, and some of the roads around here can be harsh. If I ever install lowering springs again they'll probably be JDM pinks.
Old 02-12-2008, 07:00 PM   #35
Fav Mod: alcantara...everything!
From the looks of it, these should clear with yellows and rolled fenders. I could be mistaken though, thoughts?
It looks great OP, you've really convinced me on buying a set. A local here had a set, but they were 5x100. Sadly I could not fit them on the car
Alex is online now   Reply With Quote
Old 02-12-2008, 07:08 PM   #36
I think so. You have an '04? I'm not familiar with all the differences between the model years. But it looks like they would clear even under heavy suspension compression if you have the right camber for it and/or a little fender rolling.
Old 02-12-2008, 07:14 PM   #37
Trader Rating: (14)
These wheels are pretty cool, to bad they don't come in 17x9 or wider
a local? who?
Old 02-13-2008, 04:49 AM   #38
I do have an 04, with 05 hubs My fenders are rolled but my RCE yellows have always been a bit lower than most in the rear.
Originally Posted by blindfold View Post
These wheels are pretty cool, to bad they don't come in 17x9 or wider a local? who?
Schming, for the price and weight I'd say it is a valid trade off. The local was LutfySTi on our boards. He just moved to Dubai though.
Old 02-13-2008, 06:33 AM   #39
Car: 06 CGM STI
Send a message via AIM to mav1c Send a message via Yahoo to mav1c
Hmmm...I may have to get a set of these to mount my 255/40-17 NT-01's. I was hoping to have JIC J-Force 5 17x9 +45 by the first track day in March, but it looks like they won't make it. Thanks for the info.
mav1c is offline   Reply With Quote
Old 02-16-2008, 01:18 AM   #40
Car: 2005 STi CGM DB20G
Quick 'chop to see what it might look like slung a little lower.
First post here in 2 years!
droppedclutch is offline   Reply With Quote
Old 02-19-2008, 09:16 AM   #41
Car: Silver 05 STi
Fav Mod: driving school
i just put in my order for these in 17" with 245/40 RE01R's..........
ScubaSmith7599 is offline   Reply With Quote
Old 02-27-2008, 09:59 AM   #42
This just in, the stock '05+ BBS wheels are heavier than I thought...
Weight of stock wheels, '04 & '05
19 lb 7.7 oz.
The '05 and '06 wheels are the same, aren't they? If so, I actually saved 2 pounds per corner by swapping to the TRMotorsports wheels.
Old 04-20-2008, 06:39 PM   #43
Car: silver 05 rex STi
Fav Mod: T3/T4 turbo for my ranger
Send a message via AIM to turboranger
i think i may buy these rims, i saw em on a 08 with a deeper lip to it, i wonder how he got a deeper lip then you did.
turboranger is offline   Reply With Quote
Old 06-06-2008, 09:54 PM   #44
Car: '07 Obsidian Black
Fav Mod: Stage 2 + Protune
Any more updates on this from the OP? I'd like to see how these are holding up. TIA!
karleric is online now   Reply With Quote
Old 06-09-2008, 09:04 PM   #45
Still here bro
I got these wheels late last year with 245/40/17 Yoko AVS (street tires) mounted on them. Plenty of clearance with KW V3s. I plan on installing 255s R888s later this year.
Driven them in Atlanta (bumps, potholes and what nots) and no bends/damange to the wheels. If I had to buy them again, I would.
Lutfy
Lutfy is offline   Reply With Quote
