| Grassroots STI Racer Car: 07 sti Fav Mod: whats a mod? Location: milwaukee, wi Posts: 577
IWSTI Addict since: Feb 2007 Trader Rating: (3) | thats right, and it doesnt rub! no trimming, no rolling no mods at all, stock alignment and prodrive springs. 265/35R18 kumho ecsta mx's on 18"x9" oz ultraleggera's. +55 with a 3mm spacer for strut clearance. edit: you would need a thicker spacer if you run camber bolts in the back! ![]() ![]() This ad is not endorsed by this member. Please register or login to hide this ad. Last edited by n2oiroc; 02-05-2008 at 07:45 PM. |
| | #2 |
| Wheel33tist Whore
Car: Aspen White GDF-D Fav Mod: Pastelito Racing / SFSOC Location: 0R!4ND0 Posts: 21,523
IWSTI Addict since: Dec 2004 Trader Rating: (7) | sweet, no rubbing anywhere? even under aggressive driving? can you get some measurements of ride height, strut clearance and trailing arm clearance? ![]() as long as you don't plan on upgrading to coilovers you should be good. EDIT: also post this up in the "does it fit? Look here first" link in my sig. |
| | #3 | |
IWSTI Addict since: Feb 2007 Trader Rating: (3) | Quote:
ill get some measurements soon. | |
| | #4 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | awesome, keep us posted. I'm going to have to add this to my list of known fitments. this is the highest offset 9" wheel i've seen fit. |
| | #5 |
IWSTI Addict since: Feb 2007 Trader Rating: (3) | after measuring a lot i was aiming for the high 40's (48 ish) but as you know its not easy finding anything like that. i figured i can always push a wheel out with spacers so starting high is better than starting low. i was really worried about caliper clearance on a +55 so i originally only ordered one. i was shocked to see it had over .5" with no spacer! |
| | #6 |
| S204 Racer
Car: 04 STi, 06 Altima Fav Mod: jailbreak Location: SOsocal Posts: 3,066
IWSTI Addict since: Aug 2003 Trader Rating: (2) | damn that's sweet! thanks for the info |
| | #7 |
| Senior STI Driver Car: Aspen White 06 STI Location: Seattle Posts: 316
IWSTI Addict since: Nov 2005 Trader Rating: (3) | The Prodrive springs do make a big difference! I have 265/35/18 on an 18x8.5 +45 and while completely stock, I'd rub. I had my fenders rolled, and under really aggressive cornering, I'd still rub! I got prodrive springs, and I no longer rub going around the same corners aggressively! It sounds like your setup ia a little more ideal, since you didn't have to do any fender rolling... Good work! |
| | #10 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | i believe he's running them on all 4 corners. |
| | #12 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | |
| | #15 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | a 8.5" +53mm is cutting it close with wide tires. we all know the 8" 53mm and 275 V710s don't work without spacers. This ad is not endorsed by this member. Please register or login to hide this ad. |
