Old 02-05-2008, 02:14 PM   #16
Fav Mod: Motor Mounts
IWSTI Addict since: Oct 2004
Default Re: quick question.. about 5mm spacers
Originally Posted by STIBLITZ View Post
other way around, front easy did both sides in 15 min. rear is the hardest
Really, so theres enough room to put the ARP studs in without cutting anything?
Good tips...I think I might do these this weekend. Thanks...
Old 02-05-2008, 02:15 PM   #17
Wheel33tist Whore
IWSTI Addict since: Dec 2004
in the front.
the rear is a whole other ball game.
Old 02-05-2008, 02:18 PM   #18
Fav Mod: Voltex!
IWSTI Addict since: Mar 2005
Originally Posted by T3h_Clap View Post
in the front.
^^^ FOR the troof!
im glad im done with mine so i never have to do it again!
STIBLITZ is offline   Reply With Quote
Old 02-05-2008, 02:18 PM   #19
Car: 07 sti
Fav Mod: whats a mod?
IWSTI Addict since: Feb 2007
its not black and white with all the different wheels. if you can get 10 turns out of the lugs on stock studs, then they are fine and your wasting time and money changing the studs. a 12 x 1.25 stud only needs 10mm of thread engagement. more isnt going to hold the wheel on any better.
Old 02-05-2008, 02:21 PM   #20
Wheel33tist Whore
the sole reason i haven't traded my car in for an 08 is b/c I don't want to do the rears again. j/k
Old 02-05-2008, 03:49 PM   #21
Car: aka - DownSTi
Fav Mod: Big Thanks to Jeremy @ Crucial Racing and ED @ EQ - Tuning
IWSTI Addict since: Aug 2004
thanks the teh clap for the help
im only planning on putting 5mm spacers on the rear but i dont know if i should now conisdering with safety issues and all
final question. teh clap
what do you think 5mm extra flushness/aggresive or keep them the way they are +30?
13onesti is offline   Reply With Quote
Old 02-05-2008, 03:55 PM   #22
Wheel33tist Whore
you could if you really want to but I don't think it's really needed.
they've got a pretty aggressive stance as is.
Old 02-05-2008, 03:58 PM   #23
Fav Mod: jailbreak
IWSTI Addict since: Aug 2003
hmm, you think those instructions would work for the ones that come with a 5mm spacer? maybe i'll just space the fronts wouldn't be a bad thing to have +39 up front and +44 in the rear though
Old 02-05-2008, 06:18 PM   #24
Wheel33tist Whore
I say enjoy the 44mm.
Old 02-05-2008, 06:19 PM   #25
Ive put 5mm spacers on the rear of my STi for many many Autox runs. I would not use them on the street however. Even at autox I am extremely paranoid to tell you the truth. I tighten between runs because I lose lug torque. That said...the rear tires receive the minority of the force loads when cornering...so I dont feel as paranoid about running them versus running them in the front.
Old 02-05-2008, 06:43 PM   #26
Car: 07 sti
sounds like you need some e.t. lugs. if they dont fit in your existing lug holes, drill them out to 5/8". these lugs give you an extra 8mm or so of thread engagement.
http://www.customwheelaccessories.com/ETLUGNUTS.html
Old 02-05-2008, 08:04 PM   #27
Thank you... I plan on extending the studs before the next season...
Old 02-05-2008, 08:08 PM   #28
Car: 07 sti
if you run those lugs, you dont need to. as long as you have plenty of thread engagement, its fine. it doesnt matter how you get it as long as you wind up with at least 10mm of thread engagement. keep in mind, thats the minimum, more is better, but not needed.
Old 02-05-2008, 09:21 PM   #29
Fav Mod: jailbreak
i will if they fit over the brembo's
Old 02-06-2008, 04:45 AM   #30
Wheel33tist Whore
keep us posted, i thought they were confirmed to clear.
