Old 01-25-2008, 06:29 PM   #16
Fav Mod: Motor Mounts
IWSTI Addict since: Oct 2004
Default Re: RT 615's on Stock 05 BBS
Originally Posted by wrxridah View Post
Will 255/40/17 fit on the stock 17x8's?
Of course they will...
Old 01-29-2008, 09:44 PM   #17
Fav Mod: 255's ftmfw
IWSTI Addict since: Apr 2007
Send a message via AIM to sticop
04 bbs are 17x7.5 right? how are 255's on those?
sticop is offline   Reply With Quote
Old 01-29-2008, 09:46 PM   #18
I has BOOST!
Fav Mod: LightWerkz Projector Retrofit
IWSTI Addict since: Feb 2006
Trader Rating: (15)
Send a message via AIM to MacSTi
I am running that with the Tein SS-P and I used to rub a little until I raised the front 1/4". Now it is all good..
MacSTi is offline   Reply With Quote
Old 01-29-2008, 10:13 PM   #19
Car: 07 sti
Fav Mod: whats a mod?
IWSTI Addict since: Feb 2007
the recommended width is 8.5" minimum. i never stray from the guidelines. you will have tire problems if you do.
Old 02-17-2008, 05:36 PM   #20
Car: 05 Subaru WRX STi
IWSTI Addict since: Jun 2005
I'm running 255/40 r17 on stock bbs wheels (8in version). With jdm pink springs and -1.7 camber front and -1 on the back and i have no rubbing issues. Only thing ive noticed is that the sidewall isnt as stiff as the R070's and you have to run 36psi or more in order to compesate for it. Other than that they are fine on 05+, 04 has rubbing issues.
Boxerpower is offline   Reply With Quote
Old 02-17-2008, 06:09 PM   #21
Uhhh...I am curious what tire problems do you speak of? I havent ran into any problems running oversized tires on smallish rims.
You could run 255's on 7.5" rims...hell people have even fit 275's on 7.5" rims believe it or not. I like a little bulge for rim protection but 255's will bulge quite a bit. I ran 245/45 615's on my 7.5" BBS for years. Will it be for the street or the track?
