Old 06-26-2004, 07:56 PM   #1
IWSTI Addict since: May 2004
Ok, I have about given up on the Gramlights. Any help on the 5Zigen Pro Racer GN Plus?
99m3 is offline   Reply With Quote
Old 06-26-2004, 10:53 PM   #2
Car: 05 Subaru STi
Fav Mod: the nut behind the wheel
IWSTI Addict since: Mar 2004
Send a message via ICQ to axan Send a message via AIM to axan
CHeck here http://www.importhookup.com/forums/s...dc&threadid=23
What size do you want? I'm dying to know if 17x8.5 would fit 05 sti add some nice 255 rubber and that would be sweet.
axan is offline   Reply With Quote
Old 06-27-2004, 06:59 PM   #3
Fav Mod: Kartboy SS and Bushings.
Default 05 Silver/Silver in the Bronx
LOL. Dont give up so soon. I was hoping to see a nice pic of them on an 05.
HenrysWrXSti is offline   Reply With Quote
Old 06-27-2004, 07:54 PM   #4
Default Re: Intake pipe diameter
I'm going to stay with the 17x8 and if the 17x8.5 will work that's fine with me. I'll check the site you recommended. IF I can find a set I will post pictures.
Old 06-28-2004, 07:19 AM   #5
IWSTI Addict since: Jun 2003
http://www.z1auto.com/prodmore.asp?m...els&prodid=824
FT@SGP is offline   Reply With Quote
Old 06-28-2004, 10:03 AM   #6
Car: 05 Subaru STi
The 5Zigens on Z1 site are for 04 and older subarus; however, I'm fairly sure he can get ones that fit 05 too.
Old 06-28-2004, 03:58 PM   #7
IWSTI Addict since: Jun 2004
The weight on the GN+ 18x8.5 for STI is 22LBs per wheel. Is this too heavy compare to the OEM BBS?
1_Slow_Sedan is offline   Reply With Quote
Old 06-29-2004, 12:16 AM   #8
Car: 05 Subaru STi
stock sti rims are about ~17 lb so 5 lb is kinda alot; however if you are on the budget 5zigen are some of the best cheap rims you can get you won't find much lighter 18x8.5 rims unless they are forged and cost almost twice as much. If you want something lighter stick with 17x8.5 (about 19lb) or shell out the money for some forged rims like volks, ssr or others.
Old 06-29-2004, 04:29 PM   #9
Default Detailed Instructions on How to Change Oil?
too bad that my TE37 is not going to fit on my STI... it was made to fit into my S4... but they are light....
