Old 01-16-2008, 01:34 PM   #16
Car: 2004.5 Subaru WRX ST
Fav Mod: 17x10s
IWSTI Addict since: Aug 2004
Default Re: Camber much?
Camber is ok, it's a really bad bad toe out!
loworbitSI is offline   Reply With Quote
Old 01-16-2008, 01:35 PM   #17
Car: 05 Aspen White STI
Fav Mod: Defi Gauges
IWSTI Addict since: Jul 2006
Send a message via AIM to STI_Mike
Originally Posted by nandanrp View Post
Only if you intend to run the plates with more positive camber than you can run with the camber bolts currently on the car...
Did you get an alignment after you installed the S-techs?
yes i did.
STI_Mike is offline   Reply With Quote
Old 01-16-2008, 01:56 PM   #18
Wheel33tist Whore
IWSTI Addict since: Dec 2004
you just need not wear the tires down that much, holy crap. You're way beyond the wear bars. you wouldn't have that problem if you just replaced your tires when you were supposed to.
Old 01-16-2008, 01:58 PM   #19
yes i know but i've been really short on money and my STI is my DD so yeah but i won't let it happen again.
Old 01-16-2008, 02:03 PM   #20
Car: BRP 2000 Impreza RS
Fav Mod: Coilovers`
IWSTI Addict since: May 2007
Send a message via AIM to kirrsace
pictures courtesy of meee haha
kirrsace is offline   Reply With Quote
Old 01-16-2008, 02:04 PM   #21
kirk ur not helping the problem here! haha j/k
Old 01-16-2008, 02:41 PM   #22
IWSTI Addict since: Aug 2006
Trader Rating: (14)
now we are on this subject, what's a good street camber setting? Thanks.
Old 01-16-2008, 02:45 PM   #23
Wheel33tist Whore
-1.5 to -2.0
depending how much driving you do.
if you drive aggressively to where you wear down your shoulders it will be pretty even wear.
if you drive 40 miles a day on a straight highway -2.0 is too much.
but -1.5 is a nice number IMHO.
Old 01-16-2008, 03:14 PM   #24
Trader Rating: (14)
-1.5 to -2.0
Thank you, I run -1.4 all the way around, it does get a little twitchy on the highway. Would also recommend running less camber in the rear? If so by how much when running -1.4 to -1.5 range the front.
Old 01-16-2008, 03:46 PM   #25
Fav Mod: Motor Mounts
IWSTI Addict since: Oct 2004
Holy US-Maypops!
Old 01-16-2008, 05:24 PM   #26
Wheel33tist Whore
Generally for very aggressive driving you want more camber in the front then the rear. but having below -1.5 in the rear of our car isn't exactly optimal, the cars become loose on the limit.
if you wanted to bump your front to a little more negative you could, but i wouldn't increase the rear unless you were having wheel fitment issues or too loose. If you autox or track your car i'd suggest increasing front camber to around -2.5 or so in the front for the events.
you wanna talk about twitchy on the highway, you should've drove my car at -3.0 front with 265s and 15mm spacers.
