Old 12-15-2007, 07:22 PM   #1
IWSTI Addict since: May 2007
Default A quick tire question... need help
On my sti my front tires seems to be loosing more thread then the rear. is there any reason why? another question i have is that which tires are a step stickyer then the factory tires?
BunaSTi is offline   Reply With Quote
Old 12-16-2007, 09:13 AM   #2
Wheel33tist Whore
IWSTI Addict since: Dec 2004
Default Re: A quick tire question... need help
the front tires do the following.
1.) Turn
2.) Brake
3.) Accelerate
the rear tires do the following
1.) Accelerate
2.) Follow the fronts
the front tires have more work to do.
and some bridgestone RE01R are an upgrade from the factory tires.
Old 12-16-2007, 12:16 PM   #3
hey T3h clap didnt you run 5Zigen FN01R-C 17x10 +25mm? i have cobb springs on my car if i ran with that setup will it rub the fenders?
Old 12-16-2007, 12:53 PM   #4
Car: 05 STi - Black
Fav Mod: No Lien
IWSTI Addict since: Mar 2006
Front tires also typically run less camber than the rear from the factory, so the outside shoulders will wear faster.
and no, those wheels won't fit without rubbing, rubbing really bad
Old 12-16-2007, 12:54 PM   #5
yeah the outside of my tires always goes first
Old 12-16-2007, 01:05 PM   #6
i eat cones
Fav Mod: intake
IWSTI Addict since: Oct 2006
Trader Rating: (21)
yep, outsides wore fast on ym re070's. ima grab some re01r's next summer as clap said. ftw
Old 12-16-2007, 02:24 PM   #7
Wheel33tist Whore
Those will require coilovers, no spring will allow you to run them without serious rubbing.
Old 12-17-2007, 03:13 AM   #8
Car: 02 WRX
Fav Mod: TE37 Time Attack Edition
IWSTI Addict since: Sep 2007
Send a message via AIM to wrx650ps
This camber and toe and caster stuff is so so confusing i mean not that bad but annoying..yeh annoying is more like it.
wrx650ps is offline   Reply With Quote
Old 12-17-2007, 03:21 AM   #9
aka: jnprn2003
Fav Mod: EFI Logics tunage
IWSTI Addict since: Feb 2007
Trader Rating: (13)
Bald is good...more traction JK
RONIN is offline   Reply With Quote
