Old 11-26-2007, 08:32 AM   #1
Car: 06 STI
Fav Mod: Prodrive oval tip
IWSTI Addict since: Mar 2005
Default is it safe to say that we can use sticky wheel weights on stock BBS?
some say it's ok but some say it's not. so, what's the final verdict? anyone know?
Old 11-26-2007, 10:23 AM   #2
Fav Mod: Driver weight reduction
IWSTI Addict since: Oct 2005
Default Re: is it safe to say that we can use sticky wheel weights on stock BBS?
They are safe and I insist on having them. No potential for leaks and gouges as with clip on weights. The adhesive weights on the front to need to be properly positioned so that they don't hit the Brembos with the stock or most 17" rims.
Good2Go is offline   Reply With Quote
Old 11-26-2007, 10:36 AM   #3
Spiteful Old Codger
IWSTI Addict since: Jul 2003
It's fine. Put them inboard of the calipers, otherwise they will be very, very close to hitting.
Old 11-26-2007, 03:45 PM   #4
Fav Mod: All of them
IWSTI Addict since: Mar 2006
^ I agree. I learned the hard way when a shop stacked them towards the outside of the rim. It knocked off all of the weights and scratched the calipers in the front.
Partysub is offline   Reply With Quote
Old 11-26-2007, 09:16 PM   #5
wdb
dances with roads
IWSTI Addict since: Apr 2005
Careful with that axe, Eugene. A proper wheel balancing machine will tell you how much weight to use AND where to use it -- on the inside or on the outside of the wheel. Stick-on weights may have to be placed near the outer edge in order to obtain a proper balance.
Just ask the shop to look at the rims while they are still mounted and figure out where they can and can't put the weights. A good shop will be able to take it from there.
Old 11-27-2007, 08:23 AM   #6
Spiteful Old Codger
You can get 'em plenty close enough without going right up to the outside edge. A weight that's slightly off axis works a good bit better than one that's torn off the wheel.
