| Iron Fisted | I plan on getting 245/40/17 RE01R's soon on the stock '05 BBS wheels. I know that they will fit with the stock suspension, however, will they fit on a lowered car, with BC coilovers? I don't want to spend money on tires, just to find that they rub when I get my coilovers. Also, fender rolling is a LAST resort. Thanks in advance. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #5 |
| Wheel33tist Whore
Car: Aspen White GDF-D Fav Mod: Pastelito Racing / SFSOC Location: 0R!4ND0 Posts: 21,508
IWSTI Addict since: Dec 2004 Trader Rating: (7) | as long as you're not running excessive amounts of camber using the bolts or a slotted strut you should be fine. you wont come in contact with the trailing arm in the rear, so the only concern is your spring perches in the front. I don't forsee a problem since this is a common size to run but what sort of clearance do you have now on your current setup? |
| | #6 |
| Iron Fisted | Right now I have completely stock suspension, wheels and tires. So I assume all the clearances are stock. But am I about 80% sure that I will be getting BC racing coilovers around December. I would wait to get tires afer I get those, but I need tires now so I can't wait much longer. |
| | #7 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | you should be fine, worse case you need to run a small spacer or less camber with the camber bolt. either one isn't bad when done correctly. Last edited by T3h_Clap; 10-26-2007 at 10:36 AM. |
| | #9 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | yes, a 255/40/17 fits stock wheels and stock suspension. |
| | #12 |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | also the 04s have less fender clearance in the rear. it isn't suggested to run that width of a tire on an 04. |
| | #13 |
| Junior STI Driver Car: Blue 04 WRX STi Fav Mod: Helix Downpipe Location: Katonah, NY Posts: 138
IWSTI Addict since: Apr 2007 Trader Rating: (0) | what about a 245 on an 04? and possibly with some 17x8s rims This ad is not endorsed by this member. Please register or login to hide this ad. |
