Old 10-22-2007, 01:27 PM   #1
Car: 06 STI
Fav Mod: Exhaust
IWSTI Addict since: Jun 2006
Send a message via AIM to TurboDXsti Send a message via MSN to TurboDXsti Send a message via Yahoo to TurboDXsti
Default 235/55/17
Can i fit the above tire size blizzaks on my 1" lowered 06 STi with no drivability issues/rubbing ?
TurboDXsti is offline   Reply With Quote
Old 10-22-2007, 01:37 PM   #2
Car: 2006 WRX Wagon 6 Spd
Fav Mod: Chateau Montelana 2000 Cabernet Sauvignon
IWSTI Addict since: Oct 2006
Default Re: 235/55/17
No. The circumference is different. Not because of rubbing issues, you're going to throw your speed/mileage/performance way off, not to mention put increased load on your drivetrain. You're decreasing your centrifugal leverage (i.e torque) by making the same amount of power move a greater distance. in other words you'd be increasing your final drive.
Get the proper size. And fwiw, skinnier tires do better in the snow. A 225/45/17 should suit you just fine.
Schell is offline   Reply With Quote
Old 10-22-2007, 01:40 PM   #3
Car: 06 STI
Fav Mod: Exhaust
thanks for your reply & advice
Old 10-22-2007, 01:54 PM   #4
Car: 07 UGM STI
IWSTI Addict since: Apr 2007
Check out the Miata.net tire size calculator to get a visual comparison. It also shows you the speedometer error by changing sizes, assuming it's calibrated for your current tire.
Tire size calculator
If you're still running the stock RE070's (225/45/17), going to a winter tire in that same size is actually going to be a slightly narrower contact patch due to the freakish nature of the RE070's. You can also run a 205/50/17 that is very close to the stock wheel circumference.
Matt- is offline   Reply With Quote
Old 10-22-2007, 02:45 PM   #5
Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
IWSTI Addict since: Apr 2006
145/70/17 ftw. Too bad that wouldn't fit on a stock 8" wheel.
