Old 10-18-2007, 03:46 PM   #1
Car: 07Subaru WRX STi
Fav Mod: Baby car seat
IWSTI Addict since: Sep 2007
Default 205/50 R17 and 225/45 R17 on 07 STI?
ok,
I recently ran into a guy who was selling his Porsche winter tires. The front 2 was 205/50 R17 and the back two was 225/45 R17. The tire was Dunlop winter sport M2. I'm planing on buying some 17"x7.5" winter rims to fit the STI bolt pattern
Here are my questions:
1) Can i fit 205/50 R17 on 17"x7.5"?, If so, who make a 17"x7.5" that fits an 07 STI?
2) Can i fit 225/45 R17 on 17"x7.5"?
3) Is there a problem or am i damaging my car by running two different size tires?
i would really appreciate some help here.
thank
redfoxn1 is offline   Reply With Quote
Old 10-18-2007, 04:00 PM   #2
Fav Mod: protune
IWSTI Addict since: Sep 2005
Default Re: 205/50 R17 and 225/45 R17 on 07 STI?
You have to run the same size tire on all 4 corners. Yes the 225/45/17 will fit, that's the size that comes stock on the sti
good luck
stiman1 is offline   Reply With Quote
Old 10-18-2007, 04:04 PM   #3
Black Dragon STI
Car: 07 OBP STi 03WRB WRX
Fav Mod: My whole suspension
IWSTI Addict since: Jan 2005
You must run the same size on all four wheels. Otherwise, the car will be very unhappy with you and you'll prematurely wear out your center diff.
Old 10-18-2007, 09:40 PM   #4
Car: 2oo8 aw STi
IWSTI Addict since: Jul 2004
Rota had a couple models in 17x7.5 with a 5x114.
Looks like there is the Tarmac II here:
STi & WRX Performance Parts: Rota Tarmac II Wheels (17x7.5", 5x114.3), Steel Grey
Those tire sizes are actually pretty darn close to the same in overall diameter, you could maybe get away with it. But probably not worth the risk. And used snow tires typically aren't much of a bargain, sometimes the softer tread is all on the outside, as they wear they turn into more of an all-season compound. And the siping typically wears out pretty early on too. (obviously depends on the model, don't know specifically about the M2s.)
IMHO you would be much better off looking for some used 17x8s, and go to discounttiredirect.com before Saturday, $100 off any set of tires + free shipping - the Hankook Icebear W300 and Michelin X-Ice are relatively cheap and get pretty good reviews.
Old 10-19-2007, 09:39 AM   #5
wdb
dances with roads
IWSTI Addict since: Apr 2005
Rota actually makes a 17x7 5x114.3 wheel that clears the Brembos. If I hadn't found a great deal on almost-new 225/45 Blizzaks I was going to look into going with 205/50's on 17x7's for winter. The narrower tread will give you better bite in deep snow.
Whatever you do though please go with the same size tire on all 4 corners. Differentials are expensive!
Old 10-19-2007, 10:06 AM   #6
STI Guru
Fav Mod: grip.
IWSTI Addict since: Aug 2006
rota's are ftl lol.
get the asa wheels from tire rack for like 99 a peice for winter
Old 10-19-2007, 10:18 AM   #7
IWSTI Addict since: Nov 2006
Trader Rating: (25)
Send a message via AIM to GarageSpec.com
Yes you must have same tire size in all 4 corners.
225/45/17 is ideal size.
Why not get wider rims?
GarageSpec.com is offline   Reply With Quote
Old 10-20-2007, 08:15 PM   #8
thanks for the help guys, i'm planning on going 17x8 with new M2
Old 10-20-2007, 08:33 PM   #9
Car: 06 Aspen White STI
Fav Mod: Defi's
IWSTI Addict since: Apr 2006
You've got a 07 which means your normal wheel size is 17X8. The 04s were the only ones to have 17X7.5 ...yet the tire size (225/45/17) has always been the same. Wierd huh.
Iguana is offline   Reply With Quote
Old 10-20-2007, 09:26 PM   #10
Trader Rating: (14)
half inch of extra means the tire seats better with less sidewall to flex
do not buy those tires, save up and buy 4 new tires that are the same tire size and tread depth
blindfold is online now   Reply With Quote
Old 10-21-2007, 04:53 PM   #11
wdb
dances with roads
For winter tires? For everyone? I have to disagree.
Because he's talking about winter tires, and a super-wide tire is not what you want in the snow. I've been pushed all over the place in 8" of snow on 225/45 Blizzaks a couple of times already; they float on top of the snow, don't dig in and bite.
